cosworth running on 3
my cossy started running on 3 cylinders today, number 2 is down, the rest is fine,, i have tried new plugs,leads,cap,rota arm, there is power going to the injector, tried different injectors, and tried the ecu, done a compression test and thats all fine reading 140 on number 2.
i am stuck with things to change, any help would be great,
can someone help me?
Wot did the car do when it stared to run on 3 had you over rev,ed it ? or is there just no spark in number 2 when you put a plug in the HT lead and put it on the rocker cover and run the motor
no i was sittin at 60mph then i tried to put the foot down in 5 and it started running lumpy then on 3, wen i put a plug in the lead and sit on the rocker cover it sparks,
i am confused,
i am confused,
i'd be checking injectors in all honesty, just unplug them one at a time, with your findings No.2 will make no difference, then give apower supply to the injector and listen if it's clicking, likely it's either the wiring or the injector itself.
maybe just swap injectors round and then you'll know if it's wiring.
o yea what Cossie is it?
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
