Stage 2 t3
Old Jun 11, 2010 | 08:33 AM
mr_joe0606's Avatar
mr_joe0606
Default Stage 2 t3
What is the difference between standard t3 to stage 1 and stage 2.
Also if anyone has got a stage 2 for sale let me know.
Cheers joe
Old Jun 11, 2010 | 12:48 PM
Rick's Avatar
Rick
Stage 1 usually has a 360 thrust bearing, and Stage 2 adds a 2wd cossie spec 55trim compressor wheel.
Old Jun 11, 2010 | 01:53 PM
conor.rst's Avatar
conor.rst
why not get stage 3 ?
Old Jun 11, 2010 | 02:52 PM
Rick's Avatar
Rick
stage 3 moves the power band up the rev range which some people don't like
Old Jun 11, 2010 | 03:06 PM
project rs's Avatar
project rs
but the bang is better with the s3t3, for all round use a stage 2 is the best road spec one unless you have the money for ball bearing stuff
Old Jun 11, 2010 | 03:32 PM
muz's Avatar
muz
Wye Valley Hardcore
Whats the rest of the spec?
Old Jun 11, 2010 | 03:49 PM
mr_joe0606's Avatar
mr_joe0606
Mfi,filter,3 inch bore ss exhaust 3 inch from turbo back, vernier pully, cam, full samco hoses, full fmic,chip,bailey oil breather.
Joe
Old Jun 11, 2010 | 04:01 PM
muz's Avatar
muz
Wye Valley Hardcore
Stage 2 will be fine. Stage 3 will be proper laggy on that spec.
Old Jun 11, 2010 | 04:25 PM
Rob_DOHC's Avatar
Rob_DOHC
Ye like muz said, no need for a stage 3 with out efi IMO as you won't see enough power to make it worth while.
Rob,
Old Jun 11, 2010 | 08:59 PM
Rick's Avatar
Rick
Mfi has little bearing on the power output.
Old Jun 11, 2010 | 09:15 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I disagree.
Whilst MFi can be tuned reasonably successfully, it is infinitely more difficult to optimise the timing on an MFi car, which can actually make shed-loads of difference to the power made. IMO every RST needs to be on EFi, the older they get, the worse the MFi components get and the less hard they should be pushed.
Old Jun 12, 2010 | 09:13 PM
Rob_DOHC's Avatar
Rob_DOHC
That is my take on it too Christian.
I don't personally think mfi is feasible above 200 brake with out a 5th injector kit (may as well spend a little extra on proper efi), partly because of fuelling limits but more due to the off boost fuelling.
Rob,
Old Jun 13, 2010 | 11:20 PM
SafeChav's Avatar
SafeChav
Ive got in the garage, what i recall as being a stage 3 T3, the thing is brand new i bought it as being on a car for 50 miles and then taken back off, but it is super minty mint to look at. uprated alloy actuator on it too!
Can get you pictures, let me know if you are interested im never going to fit it on a car now
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
