Inside diameter of the oil return pipe from T3 turbo to CVH block
Do you mean the rubber pipe or the metal insert that goes into the block?
In either case, don't over complicate it. You can buy the rubber hose from Ford still, although its stupidly expensive, but Roose Motorsport do a proper oil resistant silicone one. As for the metal stub, that can be bought too.
No, I just need the rubber pipe about 60-70mm length 45o bend'ish. I got a good, bearing, pipe, belt outfit locally who will have some oil/heat pipe but need size. Looks like i'll just have to get under it and pull the old one off...bit hot right now
I think you'll find that if you bend oil resistant hose through that angle it will distort on the bend. I would get the proper one from Roose if I were you. It's quite a critical part after all.
yeah yeah, I wouldn't take any risks. But you know what its like, if I can get the part today, I can do it today...Snail order is tomorrow at best. But thats me
Ok. I've called roose and the guy that would know which hose it is is on holiday. Can anyone link me to the right part? http://www.roosemotorsport.co.uk
Can anyone confirm?
Well now that you know the shape you could still call them and ask them which one is more suitable for an oil return pipe.
Also, I know that I paid about 20 quid for mine so i guess it would most likely be the first one.
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Zoggon
Aug 10, 2015 10:39 AM
Red_bull
Aug 9, 2015 08:34 AM
