Central Locking with Ford Focus
Old Jun 8, 2010 | 05:23 PM
Jaan's Avatar
Jaan
Default Central Locking with Ford Focus
Hi
I have ford Focus Zetec 3 doors i am having central locking issue
- Remote lock works fine with driver door lock/unlock (if passanger side door is locked manually.
- If passanger side door is unlocked, i can not lock the car, if i try to lock the car (both manual and remote) its flip back to unlock position.
If i have to lock the car, i need to lock the passanger door with key and then can lock driver side door with remote key.
Any possible solution?
Old Jun 8, 2010 | 05:33 PM
RichieST's Avatar
RichieST
9 times out of 10 this happens when the catch gets sticky. Try giving it a good squirt with wd40 in all the nooks and crannies round the catch, and a good soaking through the key hole too, then work it a few times to get it moving freely. If this doesn't work then it'll probably need a new door lock mechanism, but should be looked at by a mechanic first just to confirm!
Old Jun 8, 2010 | 05:52 PM
Jaan's Avatar
Jaan
Rich170, thanks for your reply, i read on another webiste this might be the cause of 'Two stage unlocking' methods.
To deactivate the two stage unlocking i tried below but did not work.
With both lock and unlock buttons depressed at the same time, wait until the indicator lights flash once. When complete two stage unlocking will be activated / deactivated accordingly.
Any other possible solution?
Old Jun 8, 2010 | 05:54 PM
siany1997's Avatar
siany1997
Just as extra note - I have an st170 with the auto-lock on when you drive off.
In March it locked itself up with the key in the ignition and engine running while it was stood.
I don't know if it's supposed to do this, but don't leave the keys in the ignition !
Old Jun 8, 2010 | 05:59 PM
Jaan's Avatar
Jaan
Thanks Sainly, its quite funny! I will never leave my key inside to protect myself from potential thieves as well as potential self-locking issue.
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
