siemens injectors
Old Jun 6, 2010 | 07:22 PM
cossiegreg1's Avatar
cossiegreg1
Default siemens injectors
im thinking of getting rid of the greys, and putting in some siemens.
will i need to change the chip?
Old Jun 6, 2010 | 07:23 PM
Yes, you will need a chip to suit the siemens, and all for no advantage, but it's your money.
Old Jun 6, 2010 | 07:29 PM
cossiegreg1
yeah but i can run more boost with blacks, greys are at limit
Old Jun 6, 2010 | 07:38 PM
BigErn's Avatar
BigErn
What size are you going for Greg?
Old Jun 6, 2010 | 07:44 PM
LHD220Turbo's Avatar
LHD220Turbo
you will def need a new chip; greys are good for 450hp ish, you sure they are going to get maxed out?
like tabs said, dont change unless you have too
edit: the siemens are all the same price 55's, 72's & 83's!
Old Jun 6, 2010 | 08:32 PM
cossiegreg1
dicko has got some 72's,
want just over 2bar of boost, dont think greys will be up to it.
Old Jun 6, 2010 | 08:35 PM
cossiegreg1
p.s its t4, ported head, cams etc.
Old Jun 6, 2010 | 08:36 PM
LHD220Turbo
for a t4 you will probably max out the 55's so you may as well go for the 83's
Old Jun 6, 2010 | 08:49 PM
cossiegreg1
greys are 501cc, 72's are 750cc.
so if the greys are "ok" surely the 72's will be fine?
Old Jun 6, 2010 | 08:51 PM
LHD220Turbo
yeah they will be; but what if you want a bigger turbo in the future? you might have to change the injectors again, so getting the 83's will future proof yourself so to speak
Old Jun 6, 2010 | 09:01 PM
cossiegreg1
if i change turbo etc, i would then totally change engine spec/chip.
i jus want to wind boost up a bit more and not melt it, so the plan was to put in the 72's to be safe.
if the car will not run with them injectors, then i will scrap that idea.Keep car as is
and next year change chip,injectors etc
Old Jun 6, 2010 | 09:04 PM
LHD220Turbo
yeah; if you change injectors you will need to change the chip regardless
Old Jun 6, 2010 | 09:15 PM
cossiegreg1
ok mate cheers.
Old Jun 6, 2010 | 09:34 PM
BRAM's Avatar
BRAM
I would have thought that greys would be ok at just over 2 bar as i was running 2 bar with only light blues in never missed a beat.
Might be wrong but im sure someone will point it out if i am.
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
cos elle
Sep 16, 2015 06:37 PM
