Help boost gauge reads 10psi dump valve goes off but no power?
Old Jun 6, 2010 | 04:42 PM
RedTurboMonkey's Avatar
RedTurboMonkey
Unhappy Help boost gauge reads 10psi dump valve goes off but no power?
Hi all how are you,
Please if there is a God of RS Turbos can someone help me!! I spent the whole of saturday removing the head of my MFI S2 to put a gasflowed one bought on eBAY only to find the casting was different so i then rebuilt the original head last night and put it back in today with new gaskets etc, now it seems i have caused yet more problems as it runs and drives but there is no power at all, the boost gauge flies right up and the dump valve blows off but i havent hardly moved anywhere, theres more power in my brothers 1.1 saxo. GOD DAMN RS TURBOS DONT YOU JUST WONDER WHY YOU BOTHER SOMETIMES!!! So please if theres anyone out there with any suggestions it would be MASSIVELY APPRECIATED.
CheeRS to all, Steve.
Old Jun 19, 2010 | 09:32 AM
crossy2004's Avatar
crossy2004
plz help im having the same problem
Old Jun 19, 2010 | 09:41 AM
botters's Avatar
botters
competant bodger
check you have put all vacuum pipes back on properly and that there are no air leaks on any of the boost pipes or manifold gaskets
Old Jun 19, 2010 | 09:49 AM
rsmark86's Avatar
rsmark86
as above sounds like an air leak maybe your air pipe to the dump valve or ecu ect.... is it a little lumpy aswel
Old Jun 19, 2010 | 11:07 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Ignition timing?
Old Jun 19, 2010 | 11:24 AM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
My old car was like this, took it to get set up and the timing was a mile out.
Old Jun 19, 2010 | 01:06 PM
conor.rst's Avatar
conor.rst
PRob timming , how did you do the timming ?
Old Jun 19, 2010 | 01:11 PM
DazC's Avatar
DazC
Sounds like ignition timing to me.....
Old Jun 19, 2010 | 02:38 PM
rsmark86's Avatar
rsmark86
as above they sound right
Old Jun 19, 2010 | 03:03 PM
pacificzetecturbo's Avatar
pacificzetecturbo
Could you have got the belt a tooth out?
cossie09
Oct 11, 2015 06:29 PM
gchristophi
Aug 31, 2015 10:36 PM
YODI
Aug 30, 2015 01:12 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
