fiesta rs turbo engine
if i am going to put a fiesta engine in my escort rs turbo, the fiesta is efi, so if i change the inlet manifold and exhaust manifold, from my mfi engine, is that all i need to change?? to make mfi, also it has a coilpack, what do i do about this as mine is on a dizzy atm ??
many thanks
many thanks
afaik yeah everything will bolt straight on, or you could fit the mfi head to the efi block unless its fooked
you will also need a efi inlet gasket and 1 for mfi too
and probably longer inlet manifold studs if using an adapter plate
JoeyBoyden
Jan 4, 2024 02:36 PM
