Slight Cracks
Old Jun 5, 2010 | 06:10 PM
Martin//TwistedTuning's Avatar
Coyote
Default Slight Cracks
alright guys,
just abit of advice, rebuilding motor going forged and all that stuff,
striped the cyl head down today and after abit of cleaning discovered these...
should i worry about these tiny little cracks at all?
there on 3 on the chambers, mostly across from valve to spark plug thread.
cheers
martin
Old Jun 5, 2010 | 06:18 PM
andy130's Avatar
andy130
scrap mate, you can test it it will no show up but once its on the car-heat it will fail
Old Jun 5, 2010 | 06:19 PM
Coyote
yeah was thinking that what with expansion and all that. best look out for another one then haha down the scrappy see what i can find monday.
Old Jun 5, 2010 | 06:45 PM
studabear's Avatar
studabear
probably be better lookin in the for sal section on here
Old Jun 5, 2010 | 06:59 PM
andy130's Avatar
andy130
if you get a EFI head of another 1.6 CVH swap valve's/springs/cam over good done
Old Jun 5, 2010 | 09:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It isnt scrap at all! It can be repaired or used as is, it's up to you!
99% of RS Turbo heads will be like this according to Ollie from NMS, and 99% of the time they will be perfectly fine to use, if it was fine before you took it off then there is a good chance it will continue to be fine.
Unfortunately the heads are 20+ years old, and so the metal is old, fatigued, and brittle
The head they suppplied me has at least one crack as above and that head cost me £700!!
But... in an ideal world it would be better to have one without any of course!
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
xrmalin
Sep 13, 2015 06:52 PM
The Enigma
Sep 12, 2015 10:12 PM
