Ford Transit Problems
Old Jun 4, 2010 | 07:19 PM
belcoo_dom's Avatar
belcoo_dom
Default Ford Transit Problems
I have a 2006 Ford Transit 2.0 Duratorque, the problem is that it has developed a servious engine knock, On further investigation the cam housing is loose, this is what was causing the knock. I have had this tightened however once started after about 5 minutes the same happens and it is loose again?
Any ideas (1) what caused this
(2) How to fix this.
ta
Dom
Old Jun 4, 2010 | 07:35 PM
Karl 3dr's Avatar
Karl 3dr
When you say the cam housing, do you mean the rocker assembly?
Timing chain tensioners are known to fail on these engines which causes the valve timing to jump, breaking cam carrier where the rocker shafts bolt on.
If this is the case and the cam carrier itself is damaged, you'll need a new cylinder head as the cam carrier and head are not available seperately.
Hope this helps,
Karl
Old Aug 31, 2012 | 01:01 PM
miffer62's Avatar
miffer62
having similar problem same van had timing chain fitted 10 days later still wont start bin in a ford garage for 6 days still wont start think its playing dead
Old Aug 31, 2012 | 01:03 PM
miffer62's Avatar
miffer62
Old Aug 31, 2012 | 09:38 PM
JOHNDQ's Avatar
JOHNDQ
Im sure you will find Ford do a updated timing chain set, we had quite a few at work with jumped timing/broken rocker arms and shafts etc and had to fit the new chain kits
Old Sep 1, 2012 | 12:24 PM
miffer62's Avatar
miffer62
there gona have another go on monday fingers x its a minibus so no bus no work thanks
Dr. Ickxs
Aug 15, 2015 11:34 AM
Mark RS
14
Aug 11, 2015 11:45 AM
Fil
14
Aug 10, 2015 07:42 PM
vdubo7
Aug 2, 2015 08:17 PM
