Old Skool RS vs New Skool RS!
Old Jun 3, 2010 | 10:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Old Skool RS vs New Skool RS!
Had a race with a mate in his MK1 FRS tonight!
Setup at Graham Goode Racing making 297bhp... We did two runs, first was a rolling start in second gear, second was a standing start..... On both runs I was pulling away all the way to 130mph (When I let off)!!
It was not by much but there was a clear gap opening up each time!
Power to weight comparisons...
FRS 228bhp per tonne
RSCabby 231bhp per tonne
Although I am now running 4psi more boost than when I was on the rollers a few weeks ago so am making a little more, maybe 235-240bhp
A good result I thought!
Old Jun 3, 2010 | 10:30 PM
juffer's Avatar
juffer
The power to weight is really close. Well done mate. What gearboxes are you both running?
Old Jun 3, 2010 | 10:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It is Geof and FYI the new FRS is 205bhp per tonne!
His is a standard FRS box and i'm still on my trusty XR3i box!!
Old Jun 3, 2010 | 10:52 PM
pani_k's Avatar
pani_k
PassionFORD Member
Far less weight in the cabby obviously helped you out quite a bit in the lower gears but would've though FRS would've roped you in a bit towards the end. Nice take though!
Old Jun 4, 2010 | 06:50 AM
Chris69's Avatar
Chris69
good job karlos, and the xr3i box held together aswell- thats a result
Old Jun 4, 2010 | 07:47 AM
crazycage's Avatar
crazycage
now try and imagine how fast a 380hp 900kg fiesta turbo is lol
Old Jun 4, 2010 | 09:32 AM
bezo's Avatar
bezo
powered by K26
maddness!!!!
sas's old erst was 380hp and weighed in at 910kgs, that was a hand full on the road.
Old Jun 4, 2010 | 09:56 AM
crazycage's Avatar
crazycage
very true,but so much fun to be had pushing so called fast cars out the way at speeds a shity litte fez shoud never be able to do.
Old Jun 4, 2010 | 10:04 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Goes to show how quick a genuine 240hp RST is, nice scalp mate
Old Jun 4, 2010 | 10:07 AM
rsmark86's Avatar
rsmark86
i must say that is quick as ive had a mk1 frs with 290bhp and 314lbs and i was chasing evos and cossies in it at lakeside lol so your rs must be a proper hoot to drive fair play karlos
Old Jun 4, 2010 | 02:00 PM
JamboRS's Avatar
JamboRS
focus rs 1672
where was the frs rolling roaded,my guess on a dastek roller.seems thats the preferred rollers for the frs guys.
ive got a graph for mine for my frs 310@fly on a dastek but no way i would say its 310,prob make nearer 250 on a dd roller
Old Jun 4, 2010 | 02:38 PM
crazycage's Avatar
crazycage
isnt a normal rst about a tonne? And the cabby close to 200kg more ? I could be well wrong tho as i know very little bout them.
Old Jun 4, 2010 | 03:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers fella's!
Cabby is 995kg RST is 980 so not much in it! With the T3 and IC you may as well say my Cabby is about 1005kg.
jamie956
42
Sep 20, 2015 07:52 PM
23
Sep 12, 2015 12:56 PM
MadMac
May 30, 2005 07:04 AM
edd
Nov 18, 2004 08:13 PM
djskitzy
Oct 12, 2004 07:25 AM
