escort van 1.8d wont start?
Old Jun 3, 2010 | 09:12 PM
pantxxxx's Avatar
pantxxxx
Default escort van 1.8d wont start?
hi, help please.
i have a 1.8d van, non turbo 51 reg.
today i drove home 30 miles fine, stopped the van for 1 hour.
When i then tried to start it, it started but was hunting for revs then stalled. it did this about 6 times and then failed to start at all.
i called the aa , they spent over a hour checking fuses, glow plugs, diesel suply and timing belt but all seemed fine so towed me home.
has anyone got any ideas? the engine turns but doesnt start.
today i had fitted a new cd player and rear speakers, with a little wiring involved. the van started directly after this.
thanks
Old Jun 4, 2010 | 03:30 PM
Is it a lucas/cav injection pump, these can suffer from sticky anti dieseling valves in the pump, this cuts or allows the fuel through, a single wire leading to the top(of the valve) on a spade terminal identifies it, can always temporarily remove the stop plunger from inside the housing see if it then ok, just means that you will have to stall the van to stop the engine before you switch the ignition off.
Vincereese
Jun 1, 2023 09:14 AM
The Enigma
13
Aug 20, 2015 09:38 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
vdubo7
Aug 2, 2015 08:17 PM
