Dual Cylinder Passive Diff Handbrake
Old Jun 2, 2010 | 10:41 AM
Blades Rally Team's Avatar
Blades Rally Team
Default Dual Cylinder Passive Diff Handbrake
Could anyone help I am looking for a piping diagram for a dual cylinder Hydraulic Clutch and Handbake lever as seen on the Dewitts WRC manual page 49 for passive diff 4x4 rally cars I have plumbed it into the Clutch slave cylinder via a T piece
1. from the foot pedal cylinder with reservoir
2. from the handbrake cylinder with reservoir
3. to the clutch slave cylinder centre push type
But all that seems to happen is that after bleeding the system the foot pedal fills the handbrake reservoir to overflowing!
Old Jun 2, 2010 | 11:05 AM
ian sibbert's Avatar
ian sibbert
[quote=Blades Rally Team;4933090]Could anyone help I am looking for a piping diagram for a dual cylinder Hydraulic Clutch and Handbake lever as seen on the Dewitts WRC manual page 49 for passive diff 4x4 rally cars I have plumbed it into the Clutch slave cylinder via a T piece
But all that seems to happen is that after bleeding the system the foot pedal fills the handbrake reservoir to overflowing![/quot
The handbrake release on the late group a car and early wrc consisted of a cylinder plumbed into the rear brake lines and a seperate circuit for the handbrake release to the centre diff....
There is no interaction with the clutch at all....
Quick Sketch
Old Jun 2, 2010 | 11:21 AM
Blades Rally Team
Ian
Are you saying that the hydraulic cylinder and reservoir were for a hydraulic centre diff unit fitted to which greabox (FFD)?
Why therfore do Dewitts state that it is for Passive diffs if it is actuated by a remote cylinder?
Old Jun 2, 2010 | 11:25 AM
ian sibbert
The one on the pic is a handbrake release, used on FFD MS gearbox's to allow mechanical rather than electronic actuation of the centre diff...the centre diff on that gearbox is passive but has a hydraulic slave cylinder to release the centre diff, hence the second master cylinder on the handbrake....
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
