GT 30 on S2
hi
Im current in the build of a 2,1 8v and im considering to go for a GT 30 turbo
but can anyone supply me with some picture of one fitted on a s2, cause im a bit worried about how much space there is..
cheers
cheers
A friend of mine did this before on his 2.1 8v zvh. External wastegate drilled and welded onto the original manifold. You might have to move the rad forward a little but it will fit
the spec is
2,1 block with H rod and 7,8:1 accrilite pistons
considering buyíng a heas from Sitech with cam and solid lifters
Brian hansen manifold
Field motorsport inlet
GT 30/63 external wastegate <-- att SAS.. is this some bulls..t to make room for?
omex 600
it looks wicked when the turbo is places over the gearbox.. its a lot more work I think..
omex 600
]http://i672.ph
otobucket.com/albums/vv87/marilynbrown/Photo644.jpg[/IMG]
