Efi idling problems pls help
Old Jun 1, 2010 | 10:35 AM
tony perth's Avatar
tony perth
Default Efi idling problems pls help
I have a 90 efi xr3i which is hard to start and will not idle properly (cutting out after Revving)
When u remove the plug from the air temp sensor it idle,s so i put a new sensor in and it started doin it again?????????????????????
Its had new leads plugs and a good clean thru!! i cant see any leaks from vacuum hoses.
Any ideas would be great as i,m at a loss.
Tony.,.,
Old Jun 2, 2010 | 07:46 PM
I'd do the spray est with wd40 or similar looking for leaks on the inlet, then check the co, as could be very lean.
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
dms04
Sep 11, 2015 01:57 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
