No power to fuel pump escort rs turbo
just bought an RS turbo, totally new to them just changed fuel pump but when ignition is turned it doesnt prime, i dont know which relay it is either to check that, any ideas? thanks.
I think you can only get them from ford.
If you have trouble finding it under the dash ive always found if you take the air vent out next to the steering wheel and shine a torch down there you will be able to see the bank of relays
hi mate you can take cap off relay and press switch manually ,or take relay out and bridge to be sure thats your problem also check heated seatin fuse if s2 or fuse on its own in between fuses if s1 , also check ground to pump hope this helps
Thanks guys, got power to it now, won't start though, starter motor seems slow dont know if it has the right battery or not, its fully charged though, any tips on getting it going would be great as i dont really know alot about it.
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
