little ends?
Old May 30, 2010 | 11:21 AM
ste45's Avatar
ste45
Default little ends?
is it true that you can replace little end bearings without taking the crank out ? cheers
Old May 30, 2010 | 11:59 AM
andy130's Avatar
andy130
yes but are they gone?
Old May 30, 2010 | 12:02 PM
ste45's Avatar
ste45
not too sure mate , i have a slight ratling noise under load , sounds like its coming from the back of the head but carnt be that as ive just had a full recon head fitted with new cam followers etc so thats all i can fink of it being know , cheers
Old May 30, 2010 | 12:18 PM
andy130's Avatar
andy130
what cam? if its banging then crank more then likey need regrind
Old May 30, 2010 | 01:23 PM
ste45's Avatar
ste45
standard cam , its not a bangin just like a fast rattle only does it wen under load , if i hold the revs it wont do it .
Old May 30, 2010 | 02:38 PM
studabear's Avatar
studabear
are you sure its not detonation
Old May 30, 2010 | 04:08 PM
ste45's Avatar
ste45
how loud can det be ? i can hear it whilst driving the car with windows up .cheers
Old May 30, 2010 | 04:13 PM
andy130's Avatar
andy130
check everything is tight?
Old May 31, 2010 | 06:36 PM
Rob_DOHC's Avatar
Rob_DOHC
I really wouldn't mate.
You will have to undo the big end caps and push the pistons rods up and out... so head off, then you will probably find your big end bearings a wank too.
With the pistons out you will need to get the gudgeon pin pressed out, this if done without car cracks the piston skirt, plus you should replace the rings whilst the pistons are out.
With the conrod in front of you its not too bad a job, but i have never heard of people changing the little end bearings and them lasting too long.
So essentially what you have just done is rebuild the engine in the car, which is a really pain and not good practice.
Don't bother mate, save your money and rebuild the engine properly later.
Rob,
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
