Zetec turbo
Old May 26, 2010 | 09:19 PM
Tricky181282's Avatar
Tricky181282
Default Zetec turbo
hi has anyone on here built a sucsessful zetec turbo lump? and would want to share some infomation with me such as were to obtain bits etc, spec for around 250 bhp, as i have decided purchase 3 dr shell with 2.0 silver top zetec in it. Heard loads of storys but wanna talk to someone with a good welth of knowledge on it. many thanks.
Old May 27, 2010 | 09:33 AM
percybigun's Avatar
percybigun
Twistin me melon man
try the search button! probably hundreds of zetec turbo builds on here.
this was mine, the conversion was done by the previous owner:
https://passionford.com/forum/restor...o-rebuild.html
goes like a bastard and i've done alot more upgrades on it since then.
Old May 27, 2010 | 02:42 PM
mobb-black's Avatar
mobb-black
you need low compression, decent conrod bolts, exhaust manifold that will take the turbo, better valve springs, good inlet that will flow well and take high capacity injectors(ie Rover T series inlet/820turbo inlet), management that can 'see' the boost, block drilled for relocated breather and an oil return for the turbo, intercooler and plumbing, k+n filter or similar alternative, focus rs 'cold' plugs
hope this helps as a rough guide for a budget build
Old May 27, 2010 | 11:40 PM
forevaford's Avatar
forevaford
plenty of good zt,s, iv got one 270 bhp, verry mild spec. std ccrank,rods and cams. accrilite pistons 8;1 comp, slightly ported head, 20 pis boost. megasquirt ecu.
0-60 in 4.6 sec
1/4 mile in 13.7 secs, in a rs turbo
Old May 28, 2010 | 04:40 PM
ST Turbo's Avatar
ST Turbo
0-60 in 4.6 sec
do me a favour, check to see if you still have your oil jets connected? Take the sump off and im sure you will have them rattleing around in there. Common problem with accrashites!
Old May 30, 2010 | 01:41 AM
forevaford's Avatar
forevaford
na mate they are still on im shure. i remember grinding grooves in skirts to clear them. like the small turbo escos pistons.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
