what power should i expect from my car
Old May 24, 2010 | 07:59 PM
rsmark86's Avatar
rsmark86
Default what power should i expect from my car
as above what should i expect from my s1 with the bits listed....
low comp bottom end with steel rods ect
stage3 big valve head
stage3 t3 .48 from cr turbos
fully ported and cross matched inlet with (efi or custom inlet plenum)
newman cam with solid lifters and double valve springs
gotech mfi
dark greens
044 fuel pump
airtech rad and front mount intercooler
airtech tubular manifold
ect ect
what power would it make with either inlet fitted so i can compare ect
and what boost levels are realistic for the spec as some say i could max out the turbo at 28psi and some say i can run like 25psi peak and others have said i need different injectors....
advise would be great guys thanks
Old May 24, 2010 | 08:01 PM
Rob_DOHC's Avatar
Rob_DOHC
I would imagine at least 260 mate, maybe more like 270?
Rob
Old May 24, 2010 | 08:53 PM
rsmark86's Avatar
rsmark86
Rob
well thats great news i would be chuffed to bits if i made around the same as karlos's car sort of 230bhp that would be lovely
but do i keep my inlet or put my efi one on
Old May 24, 2010 | 08:59 PM
Rob_DOHC's Avatar
Rob_DOHC
Karlos is limited heavily by his turbo, with a stage 3 he would be making the power above im sure. Not sure on inlet mate but im sure some one will tell you.
Have you built the engine yet?
Good luck
Rob,
Old May 24, 2010 | 09:12 PM
rsmark86's Avatar
rsmark86
Good luck
Rob,
yeh its in the car just need to finishing the loom and it will be running but its fitted with a piper 285t and i want a better cam so it can make the numbers so thats why im thinking of selling my inlet
Old May 24, 2010 | 10:46 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
I would agree with you rob about 250-270.
Old May 24, 2010 | 10:50 PM
botters's Avatar
botters
competant bodger
standard mfi inlet is capable of 300+bhp you will just need to modify it for electronic injectors or swop the lower part for an efi one
Old May 25, 2010 | 04:53 AM
rsmark86's Avatar
rsmark86
well i have a fully ported efi unit aswel so thats what i was thinking of using or the big inlet its fitted with
Old May 25, 2010 | 11:34 AM
Rob_DOHC's Avatar
Rob_DOHC
Not sure it really matters that much tbh mate.... i have heard rumours that the mfi manifold flows better than the efi??? but i have no proof to back it up. It would be easier for sure to use the efi manifold as (like botters said) you will need to get the mfi machined to except efi injectors.
Rob,
Old May 25, 2010 | 02:12 PM
rsmark86's Avatar
rsmark86
Rob,
so will the top half of a mfi s1 inlet fit a efi inlet manifold because then i wont even need a throttle cable or charge pipe just bolt in
Old May 25, 2010 | 06:32 PM
Rob_DOHC's Avatar
Rob_DOHC
Apparently not mate, but i have never had a decent look at it.
Rob,
Old May 25, 2010 | 07:05 PM
rsmark86's Avatar
rsmark86
Rob,
well ive painted up a efi inlet thats fully ported ect so thats what im going to fit
Old May 25, 2010 | 07:37 PM
Rob_DOHC's Avatar
Rob_DOHC
Thats what i would have done mate, nice and easy
Old May 25, 2010 | 09:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Either inlet is fine for 300bhp+, with good mapping 270-280bhp is possible although your engine being low comp it may be a little less
Cant remember what dark greens flow for but if it isnt enough then loose them and buy some 630cc Siemens Deka IV's they are a modern injector with a better spray pattern and are high impedance (longer life, less electrical noise) and about half the price of the greens!!
Old May 25, 2010 | 09:52 PM
jonny s2's Avatar
jonny s2
i would say anything from 250-80hp as you have the turbo and rods to run it,mfi and efi inlets can and have produced 300+hp
Old May 26, 2010 | 04:56 AM
rsmark86's Avatar
rsmark86
thats what im going to do then and if i dont sell the inlet it can go on my missus mk1 fieata rst that we are gunna start building soon
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
TIL13R
11
Aug 13, 2015 02:28 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
Old ford
Jul 31, 2015 06:50 AM
