mk5 escort pedal
Old May 24, 2010 | 01:50 PM
dave_s2_rst's Avatar
dave_s2_rst
Default mk5 escort pedal
Hi all,
I'm currently after one of these, tried burtons but they out of stock, where else around essex could I go?
Dave
Old May 24, 2010 | 02:23 PM
cj_rst's Avatar
cj_rst
S2 RST
Any Ford parts dealer? Don't know where in Essex you are but I've used the one in Thurrock before and they're quite good
Old May 25, 2010 | 10:22 PM
dave_s2_rst
evening all, got the pedal sorted from romford, nw ive got another issue, ive got the shortend quadrant, got the pedal, what cable should i run, the car has abs but the current cable is to tight, should i be using a non abs one?
Old May 26, 2010 | 05:49 AM
EssexMikeSi's Avatar
EssexMikeSi
does abs affect the way the clutch pedal works then? How much was the mk5 clutch pedal? I dont know if mine has one or not, could u take a picture of the 2 next to each other?
Old May 26, 2010 | 06:26 AM
dave_s2_rst
i not sure to b honest, burtons have a cable which states abs, i brought that one as my car has it but upon fitting it, its been too tight, now im thinking maybe the non abs is different in length and has more cable to play with?? So i should have used that for this conversion?
Old May 26, 2010 | 08:46 AM
dave_s2_rst
Old May 26, 2010 | 02:19 PM
dave_s2_rst
just a quick one,
Is the abs cable shorter than the non abs?
Old May 26, 2010 | 02:28 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
Originally Posted by dave_s2_rst
just a quick one,
I bought one from fords 5-6 months ago. My mechanic said me that rs turbo had two types of cables. One very long and an other very shorter. My new one is arround 50-60 cm. I can't remember which is for abs, (my abs went in the bin years ago). It was the last in Greece....
rex647
Mar 6, 2022 06:20 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
