ZVH Breather Return
Old May 21, 2010 | 03:39 PM
Simmo's Avatar
Simmo
Default ZVH Breather Return
I'm new to ZVH's...
When replacing the std breather setup on a ZVH engine (FRST in this case) how's best to route the return from a Bailey tank? The only obvious ways I can see is to either T into the Rocker-to-block breather hose at the bottom, or the Turbo oil return which is at the front of the block...
...at the moment i've connected it to a bottle which seems ok but the idles a little lumpier than it was before.
Old May 26, 2010 | 10:53 PM
Simmo's Avatar
Simmo
Anyone?...
Old May 29, 2010 | 04:05 PM
Bartheez's Avatar
Bartheez
http://www.zvh-build.co.uk/online_re.../build_zvh.htm
Drill an oilreturn in the block on the backside. I just did this on mine
Old May 29, 2010 | 05:20 PM
Simmo's Avatar
Simmo
Mine's already got that rear return I think and being used for the n/s rocker cover hose as per the original 1.6 block. Someone's suggested on my other thread using an ERST breather instead of a FRST which can have both rocker cover outlets going to it and still return to the bottom one you mention.
That link looks very interesting though, thanks for that!
mk1turboestate
Dec 2, 2015 08:31 PM
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
davidfordrs
Sep 21, 2015 04:23 AM
