zetec carb and ignition question
Old May 19, 2010 | 08:41 AM
mobb-black's Avatar
mobb-black
Default zetec carb and ignition question
anyone got a zetec on webers etc? and if so what did you do about emissions and ignition? have been given a set of 40's and seen cheap manifolds on ebay
Old May 19, 2010 | 10:09 AM
oldford's Avatar
oldford
With webers you can forget about meeting any emission standard. Especially when your car has a catalyst and a oxygen sensor. That won't work anymore.
Old May 19, 2010 | 10:37 AM
mobb-black's Avatar
mobb-black
yeah the idea was to simplify and ditch the ecu and all the wiring
Old May 19, 2010 | 02:05 PM
oldford's Avatar
oldford
As long as it is for use in motorsports only, good luck.
When it's for use on the normal roads, you will never pass the mot-test.
You probably have a wasted spark coil system? No distributor anymore?
How are you going to get a spark without sensors and a computer?
Old May 21, 2010 | 09:23 AM
mobb-black's Avatar
mobb-black
i dunno, thats why i was asking really. seen conversions running carbs with a black box to run the ingition, also with the head modified to take a dizzy
Old May 21, 2010 | 09:30 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
very cheap way of running the coil pack is to use the "esc" modual from an early mk3 fiesta its a little black box bolted to the fire wall. or you could use megajolt witch is a mapable ignition curve
Old May 21, 2010 | 02:01 PM
mobb-black's Avatar
mobb-black
i think i'm gonna have to admit defeat and get hold of Focus management lol
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
