brake bleed nipples
Old May 18, 2010 | 10:50 PM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Default brake bleed nipples
Hi folks
I have bought some new bleed nipples for my brakes and not sure whether I got the right ones or not
What are they like? I bought them from a motor factors as I am banned from the local Ford dealership
BTW the car is a MK4 Cabriolet with an RS conversion
Thanks
Old May 19, 2010 | 06:01 AM
BRAMMER's Avatar
BRAMMER
I bought some for 70p each the other day, should look like a bullet with a 10 or 11mm top - i think they are a pretty std app
Old May 19, 2010 | 09:44 AM
eoeumc's Avatar
eoeumc
Is that all they are though?
Do they have some sort of O ring or anything else with it? Its just that I have got the nipple on its own.
Old May 19, 2010 | 05:03 PM
Just try and see if they fit, but don't force them in, in case they are a different thread, as said should look bullet shape/ish with a tapered end with a small hole in the taper, this is to allow the fluid to flow through the drilled body, fairly common thread though on fords.
Old May 19, 2010 | 07:09 PM
eoeumc's Avatar
eoeumc
I had someone look at them and they reckon there right so just hope the old ones come out okay. I have a broken one so that will be a bit of a bummer to get out
Old May 20, 2010 | 06:04 PM
Toe Knee's Avatar
Toe Knee
oh dear!! they are a total pig to get out when they have snapped, ive never managed to get one off yet thats snapped!
As said no orings or anything on a nipple, like tabs siad the only differences are the thread ususally and the lengths can vary!!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
