xr3i help needed novice at work!!
Old May 18, 2010 | 07:20 PM
well2sound's Avatar
well2sound
Default xr3i help needed novice at work!!
took the project car to get the tracking done and noticed the nearside wheel is pushed further back in the arch then offside. Looks like its been curbed badbly and control arm has been replaced. Would damage to the anti roll bar cause this?
Old May 20, 2010 | 05:39 PM
xrmalin's Avatar
xrmalin
Could well be as you say its your project car have you had the anti-roll bar off as you might of put it on the wrong way round
mark.
Old May 20, 2010 | 06:13 PM
The tca's on these bend like jelly, would be worth checking both sides, a bent arb will also cause this.
Old May 20, 2010 | 06:30 PM
well2sound's Avatar
well2sound
ok thanks for your help, i have got a second hand s2 anti roll bar with control arms so will offer it up and see how it looks
Old May 21, 2010 | 01:39 PM
Easiest way to check arb if off the car is draw around it with a marker pen on the pavement etc, then swap it around end to end, this will soon show if it's bent, if only very slightly bent pack whichever side is needed with a few washers on the arb before putting the large washer either side of the bushes to even wheel position up, it's free and it works safely.
Old May 21, 2010 | 08:37 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
mine was exactly like this on same side, quick check underneath showed that mine was indeed slightly bent, and the nearside roll bar bush mount was cracked too. New ARB and brackets sorted it straight away...
JoeyBoyden
Jan 4, 2024 02:36 PM
marky_g
Aug 15, 2015 10:43 AM
stevierob
Aug 11, 2015 09:08 PM
col93saphcos
Aug 7, 2015 03:21 PM
