Open airfilter?
Old May 15, 2010 | 08:13 AM
db4gerard's Avatar
db4gerard
Default Open airfilter?
Hello.
Sorry if my english isn't that good, but im not from england.
I have a quistion.
I have a ford fiesta mk4 1.3 endura.
If i put a open airfilter on it.
Is it than just plug and play or should i make some fuel adjustments.
Cause im afraid that if i put one on it, the engine need's more fuel cause its getting more air.
And a nother thing, if i put one on it will it perform better.
Or whil it just make a nice sound?.
Thanks for your help and sorry for my poor english.
Gerard.
Old May 15, 2010 | 08:30 AM
Joshy's Avatar
Joshy
Dreamer
it will just make a better sound,
with such a small engine though, the percentages are so small that i dought if it would gain or lose you much anyway.
the fueling will change but there should be enough "give" in the engine map to run fine
Old May 15, 2010 | 07:56 PM
db4gerard's Avatar
db4gerard
Oke so if i put one on it.
The computer will automaticly ajust it and it will run fine right?
And is my car whit maf sensor?
Old May 15, 2010 | 08:20 PM
Joshy's Avatar
Joshy
Dreamer
the ECU can adjust a small amount to compensate, the 1.3 came with and without MAF's so see which one you have.
Its a small aluminium pipe about 3 inches long by 3 inches wide with a conector plugged into it.
if it has one then it is better suited to it, but like i say, it shouldent make much difference
Old May 16, 2010 | 07:33 AM
db4gerard's Avatar
db4gerard
Ok my car has a maf sensor so a k&n kit cant fit cause of the maf sensor?.
Then the best buy is a universal airfilter?.
And then its plug and play? no further adjustments?.
Old May 16, 2010 | 09:31 AM
Joshy's Avatar
Joshy
Dreamer
i think K&n make 2, one for a MAF and one for ones without a maf
then it is just fit and forget.
other than the noise
Old May 16, 2010 | 08:00 PM
db4gerard's Avatar
db4gerard
ow oke i only see the one whitout the maf sensor.
mmm oke i will look futher now thanks for your help mate.
Old May 17, 2010 | 07:43 AM
Joshy's Avatar
Joshy
Dreamer
no probs welcome to passion ford
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Bransby
Sep 11, 2015 01:09 AM
