Cosworth Long Stud Torque setting?
Old May 13, 2010 | 02:05 PM
rstoughy's Avatar
rstoughy
Default Cosworth Long Stud Torque setting?
Looking for the Torque settings for my engine.
Escos ST block, 6 long studs, 4 layer Mountune Gasket.
Also should i fit 4 new or old std stretch bolts in the 4 corners and what torque for them?
Soon as i have these settings the engine will be completed
As always your advice is appreciated
Old May 15, 2010 | 07:48 AM
Mike Kerbey's Avatar
Mike Kerbey
Do 30lbs, 60lbs, then 90lbs on the long studs. And use four NEW stretch bolts and torque up to 25nm, 45nm and then 180 degrees. You cannot re-use the stretch bolts.
Toe Knee
Aug 23, 2015 08:31 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Aug 14, 2015 07:29 AM
Billy_RS
Aug 3, 2015 08:43 PM
lockie
Jul 31, 2015 10:03 PM
