My mondeo has died :(
Old May 12, 2010 | 03:22 PM
theysawmecoming's Avatar
theysawmecoming
Unhappy My mondeo has died :(
Hi everyone.
I have a 03 mondeo tdci 130 zetec
The other day as I was driving I noticed a air whooshing noise when the turbo kicked in. check the intercooler to egr pipe and sure enough there was split. replaced the pipe and started to drive to mot centre. a little way down the road it started to miss and splutter and felt almost like it was going into idle/limp mode. got to the mot place and it died just outside
On re-starting, which it takes a while to do. it sounds terrible, like its firing on 2 cylinders and has a horrible metallic failing starter type of screech to it.
Mechanic took off egr, pretty gummed up, (i cleaned it about a year ago) He cleaned it, still no good.
scanned it, got code p1664 - fuel pump communication.
called AA and he also scanned it, got codes 1664/1665 but he said his scanner is better suited to cars after 05 so may not be accurate.
Asked the AA guy to take me to mechanics work shop where he said he would check the the timing chain/pulley. but all is fine.
What the hell is going on
DMF failed last year and was replaced. cam sensor replaced at around the same time for the new grey type. I did have a patch with the car that when i started it the glow plug light would flash and it would be really sluggish, but if I turned it off and back on again it was fine, it has not done this for ages though.
The aux drive pulley is squeaking.
Could the pipe splitting be the symptom of another problem or is it coincidental to something else going wrong.... Sorry about the massive post people, but if anyone has any ideas?
thanks
Old May 12, 2010 | 08:15 PM
rich2302's Avatar
rich2302
had exactly the same problem with my Alfa diesel, cleaned the EGR, same problem, tapped the EGR lightly with a hammer as a mate tried to start it and hey presto, problem cleared. New EGR valve under warranty and it was all sorted, so I would try that first.
By the way, mine called an injector fault when it happened, which was false.
Old May 12, 2010 | 10:41 PM
theysawmecoming
ok, i will give it go. thanks
Old Jun 14, 2010 | 10:28 AM
theysawmecoming
No joy what so ever, it will turn over, but wont fire at all
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
