escort 1.8 gti missfire problem
Old May 7, 2010 | 07:31 PM
jasonnjane's Avatar
jasonnjane
Default escort 1.8 gti missfire problem
i have just got an escort again but its running like crap.
changed plugs and leeds but still missfireing
lacks power and missing when driving it.any ideas anyone?
Old May 7, 2010 | 07:36 PM
wirralphil's Avatar
wirralphil
coilpack, thats if it sounds like it's firing on 2 cylinders.
Also check the maf 1st by disconnecting it, it's the 3plug connector near the airbox.
Old May 7, 2010 | 07:37 PM
jasonnjane's Avatar
jasonnjane
will do now...and also smells like its running rich and used 1/3 a tank of fuel over 60 miles.
Old May 7, 2010 | 07:45 PM
jasonnjane's Avatar
jasonnjane
pulled maf plug off and a def change in the engine so i am guessing its not that.
only thing is to do is change the coil pack...would that make it use loads of fuel then?
Old May 7, 2010 | 07:51 PM
wirralphil's Avatar
wirralphil
Did you drive it with maf disconnected? Try it driving without it connected
Reason your smelling fuel is because of the misfire.
Old May 7, 2010 | 07:53 PM
jasonnjane's Avatar
jasonnjane
yeah gave it a run around the block and even worse with it disconnected.
Old May 8, 2010 | 10:41 AM
wirralphil's Avatar
wirralphil
Coil pack then.
Old May 8, 2010 | 11:18 AM
jasonnjane's Avatar
jasonnjane
well...when buying coil pack lad in there said it might be the lamba sensor....had a look and a snapped wire....cured!
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
