indicator/wiper cluster escos.
Old Apr 8, 2010 | 07:38 PM
kcosneil's Avatar
kcosneil
Default indicator/wiper cluster escos.
would any other model fit or compatable with the escort cossie.
would removing this stop the fuel pump from work.
and does any body have a wireing diagram/workshop manual.
neil.
help!!
Old Apr 8, 2010 | 08:05 PM
St3V3_C's Avatar
St3V3_C
neil.
help!!
Higher spec other models are the same - adjustable speed intermittent and a rear wiper (rules out Orion) are what you need to look for IIRC
Stop the pump? Really doubt it - have you checked the obvious inertia switch?
They used to be on http://www.derbyshire-rsoc.co.uk/cosworthmanuals/ but it's not working
Old Apr 8, 2010 | 08:35 PM
kcosneil's Avatar
kcosneil
yeh that link is broken.
ive tried the fuel cut of switch and fuse both fine.
i removed the cluster locked the car come back to do something, gone to start the car and fuel pump dont work. everything else works fine.
Sep 28, 2015 10:05 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Bailes1992
Sep 3, 2015 02:17 PM
BlakeMoyle
Sep 1, 2015 02:24 PM
