Brake calipers
Old Apr 7, 2010 | 08:08 PM
Kammer111's Avatar
Kammer111
Default Brake calipers
I have taken my front calipers off and need the get the pistons out to inspect. Is there any way that I can get them out without using air or grease?
If there isn't anyway do you think that I could take them down to my local garage and have them blasted out there?
Old Apr 8, 2010 | 06:33 PM
Kammer111's Avatar
Kammer111
Anyone?
Old Apr 8, 2010 | 07:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
remove the pads, put them on the disc again
press the pedal to pump them out as much as you can
then slowly extract them, if possible
Old Apr 8, 2010 | 07:09 PM
James @ M Developments.'s Avatar
it depends how tight they are, if you dont have compressed air, use a foot pump im sure it would push them out if they are not to tight
Old Apr 9, 2010 | 04:08 PM
Rax's Avatar
Rax
Before I had a compressor my mate devised this
http://i487.photobucket.com/albums/r...pistontool.jpg
http://i487.photobucket.com/albums/r...lla_rax/t2.jpg
Its a bit crude but did the job,16mm socket,four slits in it so it allows the nut too travel back opening the socket and gripping the piston.We were doing it at night and everywhere was shut
Old Apr 9, 2010 | 05:11 PM
Kammer111's Avatar
Kammer111
That's clever. Got a bolt throgh the socket? I took them down to my local garage and asked the mechanic if he could blow them out with air. He said no f**king way. Far to dangerous. Will try that with my 16mm socket. I'm prety sure I havnt ever used it.
Old Apr 10, 2010 | 02:05 AM
Rax's Avatar
Rax
My mates a great bloke a member on here (John B )and an egineer where I used to work (Nasa stuff if truth bw known) You want borrow my socket lol.
Seriously mine were seized.If you cant get em out PM your addy.I will send you our outinging tool
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
