any plumbers pic added
Old Apr 7, 2010 | 03:19 PM
turbo1973's Avatar
turbo1973
Default any plumbers pic added
im trying to fit a new rad. valve but keeps leaking ive fitted int 15x8 reducer but keeps leaking at valve what im i doing wrongwill get a pic up shortly
Old Apr 7, 2010 | 04:54 PM
focusv8's Avatar
focusv8
Is that blood on the .
You don't need tape on the outside thread of the valve.
Starting with the valve, wrap a couple of turns of tape around the 15mm insert closer to the end where it tapers out.
Having put the nut then the collar (the correct way round) on the pipe, fit the 8mm olive, then wrap that a couple of turns, fit pipe into valve push right in and tighten.
Old Apr 7, 2010 | 05:05 PM
boothy's Avatar
boothy
Yeh just put some ptfe tape on the olive job done
Old Apr 7, 2010 | 05:17 PM
turbo1973's Avatar
turbo1973
the 15x8 reducer is one piece do i still need a olive
Old Apr 7, 2010 | 05:35 PM
focusv8's Avatar
focusv8
As in shears into 2 pieces to make the seal when you tighten it up enough.?
Olive not required.
Old Apr 7, 2010 | 05:38 PM
TIFF's Avatar
TIFF
Chasing Radders
put tape and jointing compound on the olive
Old Apr 7, 2010 | 05:47 PM
focusv8's Avatar
focusv8
As this (only 15 x 8)
http://www.screwfix.com/prods/23297/...Set-15-10-1-Pc
It shouldn't still be in one piece if it's been tightened up..
Pwrs2k
23
Sep 26, 2015 09:45 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
