Possibly a silly question, can you 'blow up' gauges
Old Apr 7, 2010 | 09:58 AM
cabrio zo's Avatar
cabrio zo
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Question Possibly a silly question, can you 'blow up' gauges
or the LED lights? long story short, car blew a fuse now the AFR and boost gauge don't illuminate
going to un-do and recheck all wiring to them now (were working fine before)
Old Apr 7, 2010 | 10:28 AM
cjwood555's Avatar
cjwood555
LED's can be damaged by being over-driven (voltage/current to high), over-heated or being connected in reversed polarity. They nearly always (99.99999999999%) go open-circuit though, so shouldn't be blowing fuses. It's more likely to be a wiring fault. Have you check power + earth continuity at each gauge?
Chris
Old Apr 7, 2010 | 10:32 AM
burnzy's Avatar
burnzy
burnzy
Yea I find a shotgun is a good thing to use if you enjoy blowing things up like gauges
Old Apr 7, 2010 | 10:39 AM
danzul's Avatar
danzul
noooooo..., fill the gauge with oxy-eceteline, covere the outside in wd-40, and spray a line along the floor laeding to the gauge,
take one match, light said line and happy days
Old Apr 7, 2010 | 10:50 AM
cabrio zo's Avatar
cabrio zo
I don't actually want to blow them up you fools
Pulled the headunit forward to reinsulate some wiring, carefully wedged it back in, reconnected battery then found a blown fuse (for the heater/instrument panel) so think maybe the headunit pulled on some wiring, could be unconnected
Will recheck the voltages later, both are fed from the same live and earth
Old Apr 7, 2010 | 10:54 AM
danzul's Avatar
danzul
im assuming the ignition was turned on then,
i would take the head unit back out and check all the wiring, trace it back and look for any bare or loose wires...
Old Apr 7, 2010 | 11:16 AM
cabrio zo's Avatar
cabrio zo
Exactly Danzul. Hardly rocket science, just hope the gauges haven't been knackered by a surge or something
Old Apr 7, 2010 | 11:24 AM
danzul's Avatar
danzul
i dont see why they would be,
if you have replaced the fuse and the fuse is still good and not blown again, then its possible there has been damaged caused else where, including the gauges.
i would get the multi metre out and check all the wiring, and the gauges
Old Apr 7, 2010 | 01:47 PM
Chris
A LED when connected in revserse will simply NOT illuminate, it will NOT damage it at all, connect then correctly and it will be perfectly ok.
A over voltage or current as said will kill them, reversing will not.
Old Apr 7, 2010 | 06:58 PM
cjwood555's Avatar
cjwood555
Try putting 12V backwards across an LED with a Vf of 1.4 then... Depending on the way the gauge drops the voltage to the LED you could see 12v at the diode if connected in reverse. E.g. a resistor would work the same way in either polarity, a zener would not.
IainRS1700T
Sep 25, 2015 06:44 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
dms04
Sep 11, 2015 01:57 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
