2.9 v6 12v hydraulic tappets help?
Old Mar 4, 2010 | 02:52 PM
rich123's Avatar
rich123
Default 2.9 v6 12v hydraulic tappets help?
hi does any 1 know how to re adjust hydraulic tappets on the 2.9 v6 12v bearing in mind i dont run dizzy anymore its on coilpacks
thx all
Old Mar 4, 2010 | 03:35 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you don't need to, as they are hydraulic
if you have "adjusted" them then be prepared for a world of hassle
Old Mar 4, 2010 | 03:46 PM
rich123's Avatar
rich123
no i havent adjusted them but i have stage 3 heads on it now and i wanted to make sure they are right
Old Mar 4, 2010 | 04:09 PM
dojj's Avatar
dojj
as far as i'm aware they won't need to be adjusted, but it would have been far better to have changed the cam and fitted solids while the engine was in bits if you want to make the most from teh heads
unless you are going to turbo it at a later date...........
Old Mar 4, 2010 | 05:01 PM
rich123's Avatar
rich123
i am planning on putting a better cam in at some point and its already turbo'd lol
Old Mar 4, 2010 | 06:02 PM
cosworth726's Avatar
cosworth726
hi mate if its the ford granada 29 v6 12 valve its has manual ajustment like a old crossflow
Old Mar 4, 2010 | 06:35 PM
snoopaloopa's Avatar
snoopaloopa
Not if its the later hydraulic ones that he has they don't
Old Mar 4, 2010 | 06:44 PM
dojj's Avatar
dojj
nice
Old Mar 4, 2010 | 07:28 PM
rich123's Avatar
rich123
if i remember to pre'tension them up i think you go from the dizzy order loosen the rocker just slightly and then a 90 deg turn to tighten but i cant remember for sure
Old Mar 5, 2010 | 07:47 AM
cosworth726
manual on my mates h plate 4x4 29 granada dont know about later ones v6s went out with the titanic to asmatic
yatta
May 21, 2016 10:31 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
davidfordrs
Sep 21, 2015 04:23 AM
