Mitsubishi Shogun help wanted
Old Mar 3, 2010 | 09:24 PM
MunkeyboyRS's Avatar
MunkeyboyRS
Bananas!
Default Mitsubishi Shogun help wanted
A 1994 shogun 2.8 TD smoking a lot, but is really really good on oil doesn't seem to use any. Any ideas on what's up?
Cheers Dave
Old Mar 3, 2010 | 09:42 PM
steves24V's's Avatar
steves24V's
could be a leaky injector how well does it run?
Old Mar 3, 2010 | 09:50 PM
MunkeyboyRS
Bananas!
Runs quite well, but 100% sure as its not mine, its my dads and he don't use it a great deal. I had thought about he Injectors but wasn't sure.
Old Mar 4, 2010 | 04:17 AM
fuel pump. Does the end hold back every now and then when your driving it.
Old Mar 4, 2010 | 06:56 AM
MunkeyboyRS
Bananas!
Well I've driven it to work this morning, didn't seem to hold back at all on me, took a while to start, but then I only did less than two miles across town.
If it is the injectors were the best place to get some?
Old Mar 4, 2010 | 07:04 AM
Barry_GTi's Avatar
Barry_GTi
When does it smoke? The heads are shit on them, does it use water?
Old Mar 4, 2010 | 07:11 AM
packman's Avatar
packman
Change all the filters air-fuel- oil and filter , check for air leaks then remove the injectors and get them checked.
Old Mar 4, 2010 | 09:18 AM
badnews's Avatar
badnews
i would go with injector pump seals poor starting and ramdom smoking is an issue. normaly poor to start then smoke for a short while then clear up and are ok until left over night
Old Mar 4, 2010 | 11:18 AM
MunkeyboyRS
Bananas!
Yes that you got it down to a tea. Is it a big job to change the seals? Guessing any motor factors will have them?
Cheers dave
moesin2005
Jan 23, 2022 06:28 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
rog
Aug 30, 2015 05:32 PM
Ben26
Aug 27, 2015 08:56 PM
adriansaleem
Aug 3, 2015 11:21 AM
