Dash Board
Old Mar 3, 2010 | 05:33 PM
jordan99940's Avatar
jordan99940
Default Dash Board
Hello people quick question and simple for people who know how.
how hard is it to change a dashboard because i own a Ford Escort (1998) and inside has a Wood (albeit plastic wood) dash board and personally im not a fan was wondering how many screws it has and how long of a job would it take and roughly how long would it take the 'average' person to do it. any help would be appreciated thanks
Jordan
Old Mar 3, 2010 | 05:47 PM
Icurus's Avatar
Icurus
Dead easy, and under 1 hour
Old Mar 3, 2010 | 06:25 PM
jordan99940
really thanks how many screws am i looking at roughly?
Old Mar 3, 2010 | 06:56 PM
JohnnyP's Avatar
JohnnyP
is it the clock surrounds,is the escort a escort ghia?
Old Mar 3, 2010 | 07:14 PM
jordan99940
no its a finesse but for some reason it has the ghia interioryeah thats the bit i want outa there
Old Mar 3, 2010 | 08:42 PM
Icurus's Avatar
Icurus
iirc, and I have never had those bits fitted, I think they just attach to the actual dash itself, and as such are even easier to remove, or was that on a mk5.....
On the mk5 its;
Dash clocks surround off
screw now visible either side holds part of the trims you want to remove.
Pull off 3 center switches, 2 outer ones cover srews you need to remove, that panel will now lift off.
The other side I think you have to remove the lower cover to expose another screw. But its been so long since those bits have been on my track mk5 I may be wrong!
Old Mar 4, 2010 | 08:46 AM
jordan99940
haha ok thanks cheers for the helps
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
imnoteasy
Sep 7, 2015 09:26 PM
