What generator to run Caravan/motorhome
Old Feb 28, 2010 | 09:46 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default What generator to run Caravan/motorhome
Anyone got any tips on what power generator to run a Motorhome for when im racing and staying overnight.
will need to run Fridge,a little 21"tv lights, water pump when needed?
cheers
Old Feb 28, 2010 | 09:51 PM
Jay246's Avatar
Jay246
how quiet does it need to be?
Old Feb 28, 2010 | 09:58 PM
Roosie's Avatar
Roosie
well fairly i suppose! what options have i got?
Old Feb 28, 2010 | 10:16 PM
baz walton's Avatar
baz walton
Rock Out!!
It really is a bit how long is a piece of string... with gennys the bigger the better, but it is down to your space, noise limitation and budget! anyting above 1kw will be ok, but 2kw to 3kw would be better. work out the max number of things likely to be going at once and then work out the draw. a normal kettle for instance can pull 2-3k in a spike.
Things will still work with less power, but take a long time..I know, when I had to wait 20 mins for a 4 min microwave dinner to do
Old Feb 28, 2010 | 10:22 PM
Ima Racing's Avatar
Ima Racing
No generator
gas fridge, 12v 21 inch hd tv, lights on 12v i see no reason nowadays to need a generater unless a fucking big motorhome and long stays without driving
Old Feb 28, 2010 | 10:30 PM
baz walton's Avatar
baz walton
Rock Out!!
Originally Posted by Ima Racing
No generator
or as the op says..he's going racing. How long before the van is full of handy air wrenches and compressors.
Old Mar 1, 2010 | 06:14 AM
Roosie's Avatar
Roosie
No generator
usually 3 nights without driving . and its a fair size motorhome!
Old Mar 1, 2010 | 06:16 AM
Roosie's Avatar
Roosie
this year im using all cordless impact guns etc so dont think ill be using a compressor
cheers
Old Mar 1, 2010 | 06:52 AM
steanlol's Avatar
steanlol
Like said really , big batteries and solar panels on roof to recharge them , no need for genny , im sure what you'd spend on a genny you could get a couple of good solar panels and some spare batteries and you can have peace and quiet at the end of the day , no hum from genny for you or your neighbours .
It'll offset your carbon footprint while racing lmao
Old Mar 1, 2010 | 06:59 AM
Roosie's Avatar
Roosie
my motorhome has got solar pannels, inverter, and loads of gadgets built in lol
havent figured out how to use it all yet
i have a larger battery underneath. must figure out how to use it all lol
Old Mar 1, 2010 | 07:43 AM
steanlol's Avatar
steanlol
Lol you better get the instructions out then i think and save yourself some money cos by the sounds of it you've got all the kit already .
Old Mar 1, 2010 | 11:22 AM
baz walton's Avatar
baz walton
Rock Out!!
yep, ther's no better bargin than finding you already have what you need. I think the term they use is RTFM
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
