Gearbox mounts
Old Feb 13, 2010 | 04:39 PM
Pete frst's Avatar
Pete frst
Default Gearbox mounts
Hi all,gotta change my g/box mounts,so what do you use? what did you pay?and where from?....
also does anybody run the hard motorsport mounts? and if so whats the ride like....cheers
pete
Old Feb 13, 2010 | 06:03 PM
NUTS RuS's Avatar
NUTS RuS
I run Vibratechnics motorsport mounts on the rallycar, they would be harsh on a road car
Old Feb 13, 2010 | 06:16 PM
stuart collins's Avatar
stuart collins
ive split 2 of theses in half now , had to mount it on solid ali blocks
Old Feb 13, 2010 | 06:48 PM
NUTS RuS's Avatar
NUTS RuS
I dont have your power Stu
Old Feb 13, 2010 | 07:51 PM
Pete frst's Avatar
Pete frst
cheers for the replies guys,g/box mounts seemed overlooked,my mate changes his standard ones once a year,ive just fooked my custom grs rad because of them so was gonna fit the hardest i could find as i dont care about the ride as the cars just a sunday morning toy,cheers pete
Old Feb 13, 2010 | 08:02 PM
mark2's Avatar
mark2
hi
i have run vibro tec ( split front one in half) ,poly and standard ,with standard you get a bit of soak up as you pull away and no vibration, uprated ones give very little soak up and vibrate the car badly think of it like this as you rev the car it sounds hollow inside and you feel a constant vibration through ya feet on idle not to bad on moving along thou and after a few pull aways your tuned in to the earlier biting point due to lack of soak up if ya follow me i would go for standard but if doing track work go for poly one not vibra as poly have never split on me and aint heard of them spliting so far but alot of people have had vibra go on them
mark
Old Feb 13, 2010 | 08:11 PM
Pete frst's Avatar
Pete frst
cheers mark,i look into them........pete
Old Feb 13, 2010 | 10:38 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
interestingly enough i'm on 21psi on a 1.8zvh, which puts it in the ballpark of 300bhp (not claiming an actual figure though) and just using rally design escort heavy duty mounts, not vibratechnics ones and they've lasted four months so far and it gets used regularly on boost and launches.
Old Feb 13, 2010 | 10:55 PM
Pete frst's Avatar
Pete frst
well,there looks like there's a few to choose from,im not too worryed about the vibes,just want it all tucked in nice and tight.......cheers pete..
Old Feb 14, 2010 | 07:14 AM
jonny s2's Avatar
jonny s2
ive heard the diesel mounts are stronger is this true?
Old Feb 14, 2010 | 11:02 AM
Oranoco's Avatar
Oranoco
Never had a sniff of bother with my Vibratechnic mounts and I'm hardly the most gentle of drivers
Old Feb 14, 2010 | 11:08 AM
Pete frst's Avatar
Pete frst
thats good to know,basically as long as their uprated i'll should be okay......
mjonathan24
Oct 29, 2015 10:39 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
