meterin unit...
Guest
Posts: n/a
In what way working?
Fuel delivery?
Turn it on prime pump and then undoe the bolt on the metering top if it's leaking u have petrol
Check the return line isnt blocked better yet you can if u have an air line blow through to clean any possible blockage
Last thing is the air return unit thingy i fitted one to mine and it wouldnt fire as it wouldnt prime out the air or something! That's fitted to left side of the metering unit as u look down
Fuel delivery?
Fuel delivery?
Fuel delivery?
Hope this helps.....
lol!
take an injector out, stick it in a jar.
turn the ignition on
with the air filter off push down on the large flap
if fuel squirts into the jar at a rate dictated by the flaps position its a good indication that the metering unit is physically 'metering' the fuel.....
if above goes to plan look elsewhere for the problem
Rob.
Rob.
amazing, i was going to write a message regarding the metering unit
I am pretty sure that mine is on the way out
Does anyone know where i can get a replacement for my series 2???
Sorry to hijack the thread
Thanks
Thanks
Sorry dude but not many places at all recon them, you can't get them new and if you can get a recon or a new one you will pay the world!
When you say its on the way out what do you mean? metering units get a bad rap, but often its other bits that are 'telling' them to do the wrong thing.
Rob,
Rob,
well i tested the fuel from the fuel pump under the fuel tank to the front of the car- good
Fuel from the pump to the metering unit-good but then from the metering unit to the injectors - nothing
This is why i assumed its the metering unit that is going?? i cleaned the unit and the air return next to it and car nows runs but for how long??
Guest
Posts: n/a
Have been told by a few people that the metering unit are pretty bullit proof
Will start driving the car again
Thanks everyone
James
Guest
Posts: n/a
Once it's stripped it's a PITA to re build!
Yeah take it steady mate just test it you know,If you have any worry's contact a RR company and just have them check it over (Which i would advise TBH)
another hijacker!, see the 3 pin unit on the side, i took that off and pulled the rod out, whats the best way to set the 2 fragile contacts on the main rod holding the flap in place if that makes sense?
i see the cover is adjustable to but i can put that on its original marks
Guest
Posts: n/a
There a mare once u strip them TBH,
I aint had one apart like that either so hope one of the other lad's can give u advice mate,
TBH i'd start another thread to grab attention on the matter
tried that, no reply?? i got a shot of a unit, the car wouldnt even fire and the unit moaned at me when i turned the ignition on and winding over.
didnt want to fiddle with it as it wasnt mine.
the problem with mine was the lever for the co adjuster had unclipped and was swinging loose on the main pin holding it all together
Guest
Posts: n/a
Shame ya not closer i have about 3
Guest
Posts: n/a
They could be mate pm me if ur intrested
TuRbO-CaB-LaD
Jun 19, 2008 07:46 PM
