10psi too low for my setup?
Old Feb 9, 2010 | 09:51 PM
dave_s2_rst's Avatar
dave_s2_rst
Default 10psi too low for my setup?
hi all, my car was set up last month and boosts up to 10psi. its running a chip, stage 3head, on a 2litre zetec bottom end, decent turbo and zorst. it reaches 10psi very quick and then just feels flat, what would you guys suggest psi wise to be 'realistic' for this kind of set up? Is 10psi way to low? cheers
Old Feb 9, 2010 | 09:53 PM
liam-rst's Avatar
liam-rst
shit happens
i used to run 16psi on my old zvh, depends on your turbo mate but id say 16-18
Old Feb 9, 2010 | 09:56 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
yeh 10psi is quite low 1.6cvh with t3 run that, same as cab id go for 16psi
Old Feb 9, 2010 | 10:20 PM
Matthew_M's Avatar
Matthew_M
surely boost would have been set when u had a setup?
Old Feb 9, 2010 | 10:42 PM
dave_s2_rst
yup it was set by them, along with fueling and co, i have mentioned its 'flat' so will see what happens
Old Feb 9, 2010 | 10:45 PM
liam-rst's Avatar
liam-rst
shit happens
where in essex r u an who set it up
Old Feb 9, 2010 | 10:50 PM
dave_s2_rst
hi mate, im not far from grove, they set it up
Old Feb 9, 2010 | 10:51 PM
Matthew_M's Avatar
Matthew_M
my zvh ran 18psi but i wouldnt just turn the boost up without checking the fueling
Old Feb 9, 2010 | 10:55 PM
liam-rst's Avatar
liam-rst
shit happens
i though grove were meant to be quite good? u may have an underlyin prob like a weak actuator but yet again they should av spotted it, id take it to jano if u have no joy with them
Old Feb 10, 2010 | 10:32 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
my zvh is running 21psi at the moment and is seemingly ok.
although it's way too much power to use on a daily car.
only turn the boost up if the fuelling and timing is right, otherwise it could be short lived.
Old Feb 10, 2010 | 10:39 AM
H7 CYA's Avatar
H7 CYA
10 does seem a bit low check with grove as there may be a problem. but i think a bar would be more suitable
Old Feb 10, 2010 | 11:20 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
He had it set up, they did the checks and put it to 10psi, the question wasn't whether to turn the boost up but whether or not they set it too low. HTH
I reckon at least a bar boost on that spec...
Old Feb 10, 2010 | 11:28 AM
dave_s2_rst
well previously it was running rather high boost which: (1) i found to be pointless as it felt stupidly quick for a daily and (2) felt it was rather risky incase it melted. i've not yet had a chance to get back to grove and i personally wouldn't adjust it myself no point in taking the risk. the trouble is with road being greasy/icey at times makes it difficult to go on a 'proper' run for a sound setup/test.
Old Feb 10, 2010 | 11:33 AM
Oranoco's Avatar
Oranoco
You may find they aired on the side of caution and set it up safe so it wouldn't go bang and you then return complaining your car broke (not suggesting you would of course). 10psi would seem on the low side to me but then what is teh spec of the bottom end as you've only explained what's on top of it. If the compression hasn't been lowered adequetly then 10psi might well be the safe limit.
Old Feb 10, 2010 | 11:57 AM
dave_s2_rst
yes that is true, i did consider that they may have left it on 10 to be cautious, it is running calibra pistons which i know is not the best way, i'll have a chat with them to see what they say
Old Feb 10, 2010 | 03:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What turbo is it?
Old Feb 10, 2010 | 09:22 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
ahmed bajoo is one if not the best mappers in the country and anyone who tells you different is talking out of there arse , this bloke is ex borham trained and has mapped more cars than most of us have had hot dinners , still gets called away to map wrc cars etc hes basically the dogs bollocks. your in the best hands mate thats for sure . is the car in a running in peroid of 1000 miles? , what size injectors , pumps , pressure reg , valve springs , as all these will control what a safe boost level is and if there is any probs then it would make sense to keep it low. i would personally say around 18/20 psi would be a good solid boost level
cheers paul
Old Feb 10, 2010 | 09:41 PM
liam-rst's Avatar
liam-rst
shit happens
cheers paul
who said he wasnt?
Old Feb 10, 2010 | 09:59 PM
zetaboostboy522bhp
Originally Posted by turbocabessex
who said he wasnt?
no one i was just saying hes in very good hands and iam sure there is a valid reason for the boost setting .
cheers paul
Old Feb 10, 2010 | 10:09 PM
liam-rst's Avatar
liam-rst
shit happens
he used to play with my pals frst an was always extremely good
Old Feb 11, 2010 | 07:22 AM
gingerturbo
talk about bum lick lol,
ive bin there and yeh he knows his stuff but if theres an air leak or a week actuator, or even if he thinks anything higher would be too much for the engine he aint going to wack it up, cos it would be down to them to fix it afterwould
Old Feb 11, 2010 | 10:27 AM
dave_s2_rst
totally agree wit the playing it safe, i wasn't really informed why it was low at the time, they're sound guys there just their turn around time is quite long
Old Feb 11, 2010 | 10:57 AM
dave_s2_rst
Old Feb 11, 2010 | 12:23 PM
dave_s2_rst
Old Feb 11, 2010 | 02:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by Karlos G
What turbo is it?
Also if your still MFI it could be that is all you can fuel for!
Old Feb 11, 2010 | 02:45 PM
fiend's Avatar
fiend
how long is it?
Old Feb 11, 2010 | 03:29 PM
Steve Cooper's Avatar
Steve Cooper
is it one of there own engines? if not that might be why there playing it safe. i couldnt say a bad word about grove,top work.
Old Feb 12, 2010 | 05:46 PM
dave_s2_rst
Hi mate, the engine is mine not one they did,
Been on a few runs this week and realised that I should really be concentrating on the handling side of things rather than upping anything just yet! It's a nightmare and tramlines all over the road.
with regards to the turbo, is there any way of identifying what stage it is as it was brought with the car so i'm alittle unsure . Can take a pict if it helps at all? I know its strapped onto a cossie housing with a lamda plug. I'll try and get a pict of it.
Old Feb 12, 2010 | 06:06 PM
gingerturbo
what tyres have ya got on it, have ya checked the bottom ball joints
Old Feb 12, 2010 | 07:51 PM
dave_s2_rst
the tyres are 205 which don't help at all, i suspect the ball joints are knackered along with a few of the bushes, will be jacking up the front end and will attempt to replace the bits. Deffo the next move on the car i think, a torquey car with shite handling is only asking for trouble.
Old Feb 12, 2010 | 07:55 PM
B13 RUF's Avatar
B13 RUF
RS
28 psi is what my RS used to peek at .... id recommend 18psi
Old Feb 12, 2010 | 07:58 PM
dave_s2_rst
Hi mate, is that your car in your sig? looks very familiar - was it for sale this time last year?
Old Feb 15, 2010 | 07:02 PM
B13 RUF's Avatar
B13 RUF
RS
Yea, I sold it about 1 year ago.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
Tank Mike
Sep 26, 2015 08:07 AM
