EFI/MFI Clutch
Old Feb 6, 2010 | 04:05 PM
Red_bull's Avatar
Red_bull
Default EFI/MFI Clutch
What's the difference between a CVH EFI Clutch and a MFI Clutch? I know i have a EFI Clutch around and i can't find out which one it is and as far as i know there is a difference between them...
I just can't find out what the difference should be
All of them are 220mm; and the clutch covers are all the same height; Flywheel on the clutchside looks the same.
Hope you can help
Old Feb 6, 2010 | 04:57 PM
rstdave's Avatar
rstdave
There isn't a difference as far as i'm aware, and i've had both mfi and efi!
Old Feb 6, 2010 | 05:14 PM
Red_bull's Avatar
Red_bull
On the site of burton there is a clutch where in the desription it says: AP RACING CLUTCH KIT: 220mm CVH EXTRA HIGH TORQUE ** N.B. NOT RS TURBO FIESTA MODELS.**
So there has to be a difference between the EFI power CVH's and the MFI CVH's right?
Old Feb 6, 2010 | 05:39 PM
rstdave's Avatar
rstdave
Mmm odd, i have never been aware of any differences, i know the series one's use a smaller flywheel. I happen to have the AP high torque organic (cp2000-35) and i'm on efi with a fiesta turbo flywheel
Give them a ring and ask the question, they're pretty helpful!
Old Feb 7, 2010 | 09:57 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above.
maybe the turbo specific clutch has stronger dampening springs for the turbo surge to take.
i dunno, i've used turbo and non turbo clutches on turbo engines and all worked fine till the boost gets turned up more.
Old Feb 7, 2010 | 10:01 AM
Red_bull's Avatar
Red_bull
So also the early MK5 CVH's run the same clutches then?
Old Feb 7, 2010 | 10:18 AM
JesseT's Avatar
JesseT
The only possible difference that comes to mind, is the thrust bearing bore. There are two sizes.
Old Feb 7, 2010 | 10:24 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes that could be it, the later ones are bigger and the FRST was 1990-1992/3 so sounds about right.
Old Feb 7, 2010 | 10:42 AM
Red_bull's Avatar
Red_bull
Thurst bearing = clutch release bearing or do you mean a other part?
tnx in forward
Old Feb 7, 2010 | 01:19 PM
JesseT's Avatar
JesseT
tnx in forward
Yes, same part.
Old Feb 7, 2010 | 01:37 PM
Red_bull's Avatar
Red_bull
Yes, same part.
Tnx mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
