Can someone pls tell me where all the earth points on an s2 are.
there's a hand full behind the drivers footwell, one next to the horns, one buy wiper motor, couple hidden behind dash you can see it if you take clocks out and look behind the heater vents, one in back for lights, 1 on inner wing by engine mount, 1 onto the drivers bonnet hinge, 1 from battery to wing(main earth), 1 by alternator on chasis that earths front drivers lights, thats all for now as they come to me i'll add them
drivers footwell behind speaker pod,passenger footwell behind speaker pod,take clocks out and there is 1 on a bracket on the bulkhead,they would probably be the best ones to start with if its trouble with instruments,front of chassis leg each side just down from headlights,1 by the wiper motor,1 under the rear seat,1 in the boot by the passenger side rear light
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
