focus rs engine an maybe gear box in s2?
Old Feb 4, 2010 | 11:38 PM
Micki's Avatar
Micki
me and my SB!!!!!
Question focus rs engine an maybe gear box in s2?
im planning on putting the focus rs zetec into my s2 i know this in itself is relativly straight forward when using the s2 gearbox and the 1800 zetec flywheel i dont mind doing this with quaife internals,but i didnt know if anyone had used the gearbox aswell and if so was there any mods needed to the car itself as i have my s2 fully restored and ready for spraying but dont wana get it done and have to cut the fresh paint afterif anyone can help let me know cheers.
Old Feb 5, 2010 | 07:49 AM
Karlos G's Avatar
Karlos G
Balls Deep!
The only tip I can give is not to use the S2 gearbox, even the CTS Stage 2+ box's have been broken many many times, stick with the FRS box fella!
Crazycage on here is the man to explain whats needed to fit it to the S2, i'm sure he'll be on with the details mate!
Old Feb 5, 2010 | 08:16 AM
mrviper's Avatar
mrviper
i have broken a stage 2+ bernie box at brunters
was only runnin 18 psi and rev limited to 5k (not finished mapping) in a silver top zetec turbo
3rd gear was well properly munched!
Old Feb 5, 2010 | 09:44 AM
crazycage's Avatar
crazycage
you need to trim the inner wing a little for the box to fit in the hole lol, then its just a case of fabbin up all your mounting points and doing a hydrauilc clutch conversion the rest is easy.
p-s if you cant weld dont try it .
Old Feb 5, 2010 | 12:53 PM
Micki's Avatar
Micki
me and my SB!!!!!
nice cheers for the help.Dont surpose you know what the focus box can handle in terms of power,obviously with an uprated clutch
Old Feb 5, 2010 | 01:41 PM
StephenC's Avatar
StephenC
..BS Motorsport..
crazycage, just thinking out aloud, with these inner arch mods, is it not possible to move the engine over towards the drivers side to give the room required or not? Never looked at it but was just wondering the other day.
Old Feb 5, 2010 | 01:53 PM
Micki's Avatar
Micki
me and my SB!!!!!
Originally Posted by S1 JOHN S1
What focus box? MTX or IB5?
the mtx75
Old Feb 5, 2010 | 07:51 PM
Twiddle's Avatar
Twiddle
South lincs rsoc
most of the focus rs's with big power (350 odd bhp and same torques) use standard boxes and as crazy cage said above not that hard ahs long as you can be bothered to weld and cut and shut mounts. Plus you need custom drive shafts.
Old Feb 5, 2010 | 10:49 PM
project rs's Avatar
project rs
we measured that option and still won't fit, also tried moving engine backwards to gain a little but still no good you need to take off about 15mm if my memory serves me right
Old Feb 6, 2010 | 08:40 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Just take a grinder the the engine/gearbox, soon get it in there! lol
Old Feb 6, 2010 | 08:42 AM
crazycage's Avatar
crazycage
tbh mate by time you sealed and painted the inner wing you would never know it has been done .
Old Feb 6, 2010 | 08:49 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah doesnt take much to do a tidy job, if my welding skills were better i'd do it for sure!
Had a few gearbox's fail at quite low BHP so would be nice to have something reliable in there!
Old Feb 6, 2010 | 09:44 AM
Matthew_M's Avatar
Matthew_M
im seriosly looking at doing the box conversion has anybody got any pics of the mounts that they had to make?
how much work is it to modify the standard frs driveshafts?
started fitting my hydralic clutch master cylinder yesterday
thanks to karlos's guide :thumbsup
Old Feb 6, 2010 | 12:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i'll get round to finishing that when I get the box back in!! lol
Pistons arrived today so at last I can commence the rebuild!!
Old Feb 6, 2010 | 12:17 PM
liam-rst's Avatar
liam-rst
shit happens
u ripped yor car apart since i see u in southend in the summer then karlos?
Old Feb 6, 2010 | 12:30 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol
Yes mate, I had a valve seat drop from the head destroying my engine!!!
So building up a new one, with a new block, forged pistons and rods (Wossner, PEC), and a repaired NMS head!
If you want to see what happened look here.... https://passionford.com/forum/ford-e...use-found.html and here... https://passionford.com/forum/ford-e...0396-well.html
Old Feb 6, 2010 | 12:48 PM
liam-rst's Avatar
liam-rst
shit happens
lol
lol i had a valve snap an destroy my entire engine too lol, just built up a standard 1 i had layin around while im building my 1800 low comp cvh, rs turbo power, u gotta love it lol
Old Feb 6, 2010 | 01:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol Yes mate! One mission after another!!
Old Feb 6, 2010 | 01:02 PM
liam-rst's Avatar
liam-rst
shit happens
i got some pics of mine on my fb, how would i get them off to post up? alot of u would be surprised, if the damage wasnt so spectacular i wouldnt av laughed at it lol
Old Feb 6, 2010 | 01:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Right click them and select 'Save As' then use www.imageshack.com or www.photobucket.com to put them up on here.
Old Feb 6, 2010 | 01:12 PM
liam-rst's Avatar
liam-rst
shit happens
sweet, ill crack on with it
Old Feb 6, 2010 | 01:16 PM
crazycage's Avatar
crazycage
i made my shafts from a set of fiesta ones and a set of mondeo ones on my car and a set of escort ones and a set of focus ones on ricks car both of them run big power with no probs and have done for over a year now.
ill post some pics of how i done it when i get time.
Old Feb 6, 2010 | 01:34 PM
crazycage's Avatar
crazycage
heres a some pic's that i have just gone and took there is very little paint if any as it the coversion was done in a rush last year for classic ford show !! so its all out over winter for some sealer and paint .
btw i run five mounts, two on the engine and three on the gearbox because i hammer mine hard off the line at the pod on 888s .
Old Feb 6, 2010 | 09:40 PM
project rs's Avatar
project rs
fancy putting those shonky pictures up could of waited till i gave it a blow over for you to smarten it all up p.s like the new foot wear shame you lost the other leg though bet most people be surprised they're getting beat by a 1 legged hill billy
Old Feb 6, 2010 | 09:51 PM
jonny s2's Avatar
jonny s2
whilst were talking about this conversion,if i put the silvertop zetec together with the focus rs box clutch an flywheel, can i get away with running the 1.8 sump? or does it have to be the 2.0 blacktop sump?
Old Feb 7, 2010 | 09:04 AM
crazycage's Avatar
crazycage
it will bolt to the 1.8 no probs but there will be two extra bolt holes in the bottom of the box doing nothing but so what i have never got round to putting them in mine lol.
Old Feb 7, 2010 | 11:23 AM
jonny s2's Avatar
jonny s2
cheers gary,so this will be fine
Old Feb 7, 2010 | 11:49 AM
Rick's Avatar
Rick
pity i havent got any pics of my mounts/bay as we made that look a lot nicer. The inner wings are tapered in on both sides, seam sealered and painted it and it looks spot on.
Thing is, the above setup works -i've launched it at the pod with Micky t's and Gary has done countless more - it's goto have more than 50 full bore launches under its belt.
Rick
Old Feb 7, 2010 | 11:57 AM
crazycage's Avatar
crazycage
Rick
i learned a lot from doing mine that made the job easier and nicer to do yours lol.
but that said it does work very well and thats all that matters to me fuck what it looks like its no show car.
Old Feb 7, 2010 | 12:40 PM
Rick's Avatar
Rick
defo mate
Old Feb 7, 2010 | 12:46 PM
botters's Avatar
botters
competant bodger
i know with that box and a cvh if you lower the engine 20mm you dont need to cut the inner wing dont know if poss with a focus engine tho
Old Feb 7, 2010 | 04:19 PM
crazycage's Avatar
crazycage
Rick
looks a little better now mate .
Old Feb 7, 2010 | 04:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Very tidy job!
Old Feb 7, 2010 | 04:36 PM
StephenC's Avatar
StephenC
..BS Motorsport..
interesting, liking the sound of that
Old Feb 7, 2010 | 05:23 PM
crazycage's Avatar
crazycage
Crazy u could have painted all the back panel too
Look's nice BTW
was going to but thought fuck it you will never see it when the metal trim goes back on lol.
plus like i said its no show car.
Old Feb 7, 2010 | 05:24 PM
crazycage's Avatar
crazycage
shame the focus rs box wont fit on a cvh then.
Old Feb 7, 2010 | 07:56 PM
project rs's Avatar
project rs
gary that looks so much better and all your black bits are done just silver to go now be all together soon
