S2 sunroof drains leaks
Old Feb 2, 2010 | 02:45 PM
rslove's Avatar
rslove
Default S2 sunroof drains leaks
hello, were do the front sunroof drains exits is it the sill? and how do i clear them cause i do believe there blocked (waxoil).
also does anyone know how to remove the fuse box so i can check for a leak there.
cheers!
Old Feb 4, 2010 | 02:12 PM
Micki's Avatar
Micki
me and my SB!!!!!
hi mate the front drains are a thick plastic pipe that run down the a-pillar and exit through a small hole on the sill.if your sills had welding done near the front chances are they may have been patched over.hope this helps but if not you could have a leak on the bulkhead above the fuse box or even from the front screen behind the rubber reason i say this is im currently restoring my rs and was leaking from both these areas.hope yours is a quick fix.
Old Feb 6, 2010 | 07:32 PM
rslove's Avatar
rslove
also found out today back ashtrays full of water!!!!!!
so being completely interior stripped tommorrow.
Old Feb 7, 2010 | 10:54 PM
Micki's Avatar
Micki
me and my SB!!!!!
just take the roof lining out mate i think you might find the sunroof inner tray is rusted through,had this on a few of mine,with the one im doing at the mo i opted for a complete carbon fibre roof check them out at WWW.CARBONDELIGHT.COM, it does away with the whole roof 4 inches from the gutter,i weighed the original roof when chopped 23kg and the carbon one was 3kg.but you do have to have a rollcage for obvious stregthening reasons.
Old Feb 8, 2010 | 12:10 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
headache.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
stevecfrst1
Sep 30, 2015 05:18 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
