whats my zetec turbo worth
virgin only up the A hole
hi my engine is currently in a mk3 fiesta running un mapped an un used under load it has
frst inlet
t3 turbo
ofac management
rover turbo 400cc injectors
oil breathers in block an turbo oil return to block
its a 2.0 ltr with skimmed pistons only downside
but has had new oil pump an other bottom end related parts
using a focus steel head gasket
only getting rid to make way for 2.1 conversion an looking to free up some cash by selling this any price guide would be appreciated before i place for sale thanks sy
also double capacity alloy cooler
frst inlet
t3 turbo
ofac management
if you get the right person id say Ł500 as management is worth 100-150, adapter plates arent cheap so say engine is around Ł200, turbo Ł100 intercooler Ł70 then injectors etc so id be saying around Ł500 mark if that helps
