spark plug 4 issues
Old Jan 29, 2010 | 09:28 AM
dave_s2_rst's Avatar
dave_s2_rst
Default spark plug 4 issues
hi guys, seem to have an issue with plug 4 on the car. When cold the plug is non existent and only seems to run on the other 3, but once warm it kicks back in. Any ideas on what may be causing this, its still running mfi. The injectors and plugs where checked and hopefully will be checking the metering head today. anyone had similar issues with thers? thanks
Old Jan 29, 2010 | 09:31 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
have you checked for damp in the dizzy?
also check rotor and cap, they may just need replacing, not expensive at all, about a tenner.
Old Jan 29, 2010 | 09:46 AM
liam-rst's Avatar
liam-rst
shit happens
all 3 of my rst's + my cab have done this an seemed to be rotor an cap, only happens on cold damp mornins or to me it did
Old Jan 29, 2010 | 09:53 AM
dave_s2_rst
cheers for the replies guys. I'll get this checked over, the car's at grove at the moment getting some other bits done, not sure if mark has check the cap or rotor arm yet. Will keep you all informed.
Old Jan 29, 2010 | 10:20 AM
lurch1977's Avatar
lurch1977
Cold start valve on the inlet manifold, could be the problem
Old Jan 29, 2010 | 10:27 AM
It is also classic of a dud plug, why not swap no 1 and 4 around and see if problem swaps also.
Old Jan 29, 2010 | 10:47 AM
dave_s2_rst
hi mate, i had changed the whole set over for some decent plugs only to find no change.
Old Jan 29, 2010 | 12:28 PM
dave_s2_rst
right, had an update, its piston 4 which drops , not the plug and the car gets very tappety, suspected issue with the tappets as the spark appears to be fine, could it be dodgy tappets failing when cold? Resulting in piston 4 not functionin until warm?
Old Jan 29, 2010 | 01:15 PM
JesseT's Avatar
JesseT
Could also be a cam on its last legs.
Old Jan 29, 2010 | 10:08 PM
dave_s2_rst
ouch, didnt think about the cam! Lets hope its not!
Old Feb 6, 2010 | 09:41 PM
dave_s2_rst
jus an update, turned out to be the tappets nw running much better on start up
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
