XR3i Cabby Headlamps...
Hi...Trust you all had a Good Christmass....
Can anyone tell me the easiest way of accessing the lower attachment
screw of a MK 5 XR3i headlamp unit?....I,ve removed the front indicator
unit as per MR Haynes Manual ..but find it an almost impossible task.
AND......
are all the MK5 and MK6 headlamp units interchangable,as I must change my RHD units to LHD due to our move to France....
.............. Happy New Year..........Rustler........
AND......
As above its best to get the bumper off, the lights are interchangeable as far as I am aware, however you may need to hack some of the slam panel away as the MK6 ones are a single peice unit, also you will need to swap the front wings as they are a different shape.
