CH Experts..... Ravenheat boiler.....
Old Dec 28, 2009 | 06:02 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default CH Experts..... Ravenheat boiler.....
Our house had a new ravenheat B&Q combi special fitted about 5 yrs ago when we bought it. Always has been a pain in arse with various problems, but currently have a odd one....
Central heating side is fine, Hot water though only get luke warm no matter how high you have setting, you have to throttle tap back by over half to get it hot enough to wash in etc, Baths are never hot enough.
Any ideas??????
Old Dec 28, 2009 | 07:41 PM
markk's Avatar
markk
diaphragm on the changeover valve has rotted/split.
Old Dec 28, 2009 | 07:42 PM
Dunccoss's Avatar
Dunccoss
sounds like divertor valve
Old Dec 28, 2009 | 07:44 PM
FORD RS MAD's Avatar
FORD RS MAD
Ford model mad
Any ideas??????
I had a similar problem with my combi,same thing,if you open up the hot tap too much it would run colder.I was told it was a heat exchanger,if the hot tap was open too much the water flow was too fast going through it for it to heat up.Also recently if i was running hot water the rads came on,that was a faulty diverter valve.
Good luck.
Old Dec 28, 2009 | 10:56 PM
dannyblackpool
Boost Builder
IS IT SUMMIT I COULD CHANGE, CAN PUT MY HAND TO MOST STUFF.....
oopsss caps lock
Old Dec 29, 2009 | 09:05 AM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
It will be either the divertor valve letting by or the hw heat exchanger.
Old Dec 29, 2009 | 11:26 AM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
I have had a Ravenheat boiler fitted since 2003 and I am on British Gas' service plan. I was told a couple of years back when I joined that it would probably be heaps of trouble but apart from having one valve changed, its been okay. They aren't a B&Q boiler are they? I know they are made at a place in Morley, well, they were.
Old Dec 29, 2009 | 11:59 AM
dannyblackpool
Boost Builder
what am i looking at for one changing roughly???
Old Dec 29, 2009 | 12:09 PM
LHD220Turbo's Avatar
LHD220Turbo
that's what mine was, but i had no hot water at all - the diaphragm was split really bad tho
Old Dec 29, 2009 | 03:52 PM
Steve the Plumber
What, for the parts, or to do the whole job?
Old Dec 29, 2009 | 03:59 PM
dannyblackpool
Boost Builder
whole job
Old Dec 29, 2009 | 04:03 PM
Steve the Plumber
Couple of hundred quid probably.
Old Dec 29, 2009 | 04:05 PM
dannyblackpool
Boost Builder
do it meself if it is lol
Old Dec 29, 2009 | 04:07 PM
Steve the Plumber
LOL.
It aint rocket science.
Old Dec 29, 2009 | 07:34 PM
Jon(M600BHP)'s Avatar
Jon(M600BHP)
If the boilers coming on but the Hw is only luke warm, Its probably the Plate H/exchanger blocked, Needs stripping and cleaning
Old Dec 29, 2009 | 10:08 PM
dannyblackpool
Boost Builder
Jon ive had a feel and when it fires up (which is getting tempermental) the radiator system is getting hotter than the hot water system so looks like diverter
Old Dec 30, 2009 | 06:14 AM
Jon(M600BHP)
What so your radiators come on when its on hot water only? If so then its prob divertor valve passing
Mike C
Nov 26, 2010 08:23 AM
dannyblackpool
13
Apr 12, 2010 10:30 PM
