Power steering Pipe
Hi there
I need the poer steering pipe that goes from the pump to the rack, held on to the rack by a 10mm bolt and a wierd circular arrangement on the pump side, always bend and quite often brake.
Quick as poss please guys.
Rob
Rob
I've recently bought one for my 2wd Saph (Ł90)...... 2wd one is still available, but the 4x4 one isn't (so I'm told)
not sure what difference's there are between the 2wd & 4x4 pipes....... could just be the length???
I work for a hydraulic's company that makes hose assemblies..... I looked at making a hose myself, but the end into the rack is "special"..... pump end is just a banjo & I have them in stock
The other idea I had involved tapping a thread in the rack & do away with the "special" end
If you can't 4x4 pipe maybe something could be put together by a hydraulic hose company using the rack end of a 2wd hose as a starting point
give me a call Iam in Essex Sunday morning collecting a call I can meet you
deathrider666
Sep 28, 2015 06:12 PM
