BMW E36 Compact - Central Locking help needed
Old Jun 12, 2009 | 02:36 PM
RS Bowk's Avatar
RS Bowk
Default BMW E36 Compact - Central Locking help needed
I have a E36 shape BMW 316 Compact on a V Reg. Can anyone help with why the cnetral locking doesnt work?
I dont think it should have remote locking should it? If this is the case then even if i didnt have the remote the central locking should still activate when the drivers door is locked and unlocked with the key? Am i right?
We have replaced the control module that does the locking, windows and various other interior items but this didnt cure it.
Can anyone tell me what the wire colours should be for Lock and Unlock going into this box?
Any other help would be gratefully received.
Old Jun 12, 2009 | 02:51 PM
brad's Avatar
brad
Have you checked the switch on the back of the lock inside the drivers door ?
Old Jun 12, 2009 | 02:52 PM
RS Bowk's Avatar
RS Bowk
What switch is this? Not 100% sure what you mean and where?
Old Jun 12, 2009 | 03:01 PM
brad's Avatar
brad
Inside the drivers door theres a trigger switch that is attatched to the lock mechanism , its the one that sends the signal to the locking interface(certain models/not sure on yours) . its easy to find as its the only wires that go to that specific part.
We had 2 or 3 breakdown which caused the central locking to instantly unlock itself when you tried to lock the doors. its expensive from a mainstealer and maybee cheaper to fit an aftermarket remote locking system if its buggered.
Old Jun 12, 2009 | 03:03 PM
RS Bowk's Avatar
RS Bowk
Doesnt sounds like it is that as the doors all lock manually and unlock fine also.
Do you know what colour wires are lock and unlock?
Old Jun 12, 2009 | 04:28 PM
bristol_fez's Avatar
bristol_fez
the solenoids are known to go on these, you might want to start there.
Old Jun 12, 2009 | 04:37 PM
RS Bowk's Avatar
RS Bowk
Would one solenoid going stop all the doors working no matter wether its the drivers or passengers door you turn the key in?
Old Jun 12, 2009 | 09:44 PM
RS Bowk's Avatar
RS Bowk
anybody?
Old Jun 12, 2009 | 09:47 PM
AlexF's Avatar
AlexF
when you push the passengers door pin done does the central locking activate?
Old Jun 12, 2009 | 09:56 PM
RS Bowk's Avatar
RS Bowk
NO
Old Jun 13, 2009 | 02:08 PM
RS Bowk's Avatar
RS Bowk
Any other sugestions?
Idealy i need to know the wires that lock and unlock so i can put 12v to it to see they respond.
JoeyBoyden
Jan 4, 2024 02:36 PM
JPA
Nov 8, 2015 12:26 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
col93saphcos
Aug 7, 2015 03:21 PM
