question about fitting a msd wasted spark driver
probably a stupid question but i wanna be sure before cutting up my ecu
the grey wire that says its the rev counter wire, says you connect to pin 9 or 21 in the ecu
it then says that the grey wire always connects to the pin that you fit into the ecu multiplug
21 for non air con cars or 9 fo cars with air con.
what i dont get is pin 21 is the air con input into the ecu and pin 9 is blank
as i dont have aircon i dont have anything connected to pins 9 or 21 in the ecu.
and from the wiring diagrams ive got nothing is connected to either of them anyway, and the rev counter takes it feed from coil/ign amp
any1 know what im supposed to do?
will call msd later but they aint open yet.
Stu,
Its nearly sorted.
I have added the ability to read chip files and view them in a formatted method including encrypted files.
I.E. instead of reading just bytes it will convert the fuel map to milliseconds and spark tables to degrees ..etc..
I will be giving it away 100% free including source code to keep the admin on this site happy.
Its nearly sorted.
Stu,
It already works as a diagnostic tool/monitor.
As its you, PM me your address and I will send you a copy as it stands with a lead.
I wont be able to send it till early next week as I am not home till then.
All FOC of course
All FOC of course
Stu,
Its nearly sorted.
Its nearly sorted.
so wish i could get into this, but alas i need a car first
Escortdriver1
Aug 19, 2015 09:02 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Escortdriver1
Jul 31, 2015 02:36 PM
