4x4 cosworth non power steering rack
Old Jun 10, 2009 | 12:22 PM
mk3cosworth's Avatar
mk3cosworth
Default 4x4 cosworth non power steering rack
Is there such a thing as a non power steering rack for the 4x4 cos or 1 that will fit as i want to remove the power steering off the mk3, is there a aftermarket quick rack type or simlar
Old Jun 11, 2009 | 09:36 PM
mk3cosworth
any ideas
Old Jun 11, 2009 | 09:40 PM
The Youth.'s Avatar
The Youth.
presumambly one would fit a 2wd x member but to fit it to a 4x4 x member I guess you would need to weld on new brackets to the rack
steve
blacky.'s Avatar
blacky.
think its only us looking
Old Jun 11, 2009 | 09:50 PM
jacko's Avatar
jacko
just take the pipes off and use corsa or punto electric type i have a pinto one
you can user
Old Jun 11, 2009 | 09:52 PM
carlo's Avatar
carlo
Andys is just a 1.6 non power steering rack with corsa motor & fancy control unit works a treat
Old Jun 11, 2009 | 09:54 PM
jacko's Avatar
jacko
its the mounting thats dificult carlo andy has a differrent one off sub frame
Old Jun 11, 2009 | 09:56 PM
carlo's Avatar
carlo
Im sure you could rig it up mate
mk3cosworth
ye thats it, and i dont want the weight of the electric motor either
Old Jun 11, 2009 | 09:58 PM
carlo's Avatar
carlo
Dont think its that heavy is it ?
Old Jun 11, 2009 | 10:00 PM
jacko's Avatar
jacko
you will need wheatabix and big arms then lol
Old Jun 11, 2009 | 10:07 PM
Martin Hadland's Avatar
Martin Hadland
Why would you want to remove the p/s?? Do you need the space or just want a manual rack?? If its the later you will regret loosing the power assistance.
Old Jun 11, 2009 | 10:08 PM
blacky.'s Avatar
blacky.
i used to run my pug with the pump removed & it was a pig when stood but ok on the move
wenny we will drop the belt off on wed night so you can see what its like
its a bit heavyer with fluid still in the rack
Old Jun 11, 2009 | 10:09 PM
blacky.'s Avatar
blacky.
martin weight is the enemy
Old Jun 11, 2009 | 10:16 PM
The Youth.'s Avatar
The Youth.
a power rack with the pump removed is far heavier to run that a non powered rack on the same car taking the belt off won't prove anything
steve
Old Jun 11, 2009 | 10:28 PM
jacko's Avatar
jacko
thats only cos you are having to push everything about without help
ifr you disconectr trhe pipers itr will just become passive job done
Old Jun 11, 2009 | 10:34 PM
blacky.'s Avatar
blacky.
as jacko said with the fluid out its easyer
i did ford fair n the nail last year with no pas belt as the tenshioner bolt snaped on the run down never stoped me doing the track time & getting home again
Old Jun 11, 2009 | 10:41 PM
mk3cosworth
yes its just to save weight and maybe slight power running the pump
i might fit the corsa c pump to the column if the steerings to heavy
Jay,
Aug 24, 2015 05:26 PM
borboyous
Aug 22, 2015 11:17 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
